FS: Technics 1200 + Audiomods Classics + mods
0 Members and 1 Guest are viewing this topic. Read 3045 times.
doctorcilantro
« on: 10 Dec 2013, 05:34 am »
Happy holidays,
I live overseas most of the year, and I scooped up what was to be a backup table, or 2nd system table. Problem is, I don't even have a home yet, nor a 2nd system. This was to be the 1st piece, but I'm going to hold off and just focus on setting up my Lenco here.
I'm asking $2000 shipped CONUS for Technics 1200 MKII with an Audiomods Classic tonearm, and the unit has some RoyaLcraft mods and external PSU and matching semi-gloss maple wood case for PSU and 1200.
The mods include:
    3 Point Tonearm Isolation System
    Wood-In Platter
    Compound Loaded Deck
    Aluminum Thrust Plate
    Separated Power Supply
    Re-brushed platter (aesthetic)
    White LED
    External psu wood case semi-gloss (maple) (with matching Technics feet)
    Hardwood case semi-gloss (maple)
    1200 bonded to wood case - stock feet moved under case
Audiomods Classic details:
Tonearm is Audiomods Classic. This one has the polished finish, with brass finish counterweight and stub. No micrometer. This one also has a Series V Cardas 5-pin connector, Series IV bearings, silver internal wire, full set of headshell shims, and a transferable warranty from Audiomods. All extra parts included, manual, wooden case, etc.
You'll have to provide your own RCA > DIN cable and a cart, unless you want a sealed AT33PTG for +$500.
I don't have pics yet as Roy is working on the table. Please PM if interested. Tempted to keep this little giant-killer but like I said, I have my hands full with Lenco and Audiomods V. I have feedback on Audiogon and eBay if you want to contact me through those systems for piece of mind.
roscoeiii
Re: FS: Technics 1200 + Audiomods Classics + mods
« Reply #1 on: 10 Dec 2013, 05:06 pm »
Those Audiomods are great arms.
doctorcilantro
« Reply #2 on: 23 Jan 2014, 10:50 am »
Please let me know if you are interested, as a cart can be bought and mounted for you by Roy and shipped ready top play. It also has a brand new bearing going in.  Original has a badly bent thrust plate, usually these can be straightened out but this one is beyond repair. The thrust bearing is also shown. It has a small round Teflon pad, when these are new they are flat, after many years of proper use they will show a small dimple from normal wear.
Other options include dust cover, rubber mat, and Technics feet mounted to underside of new wood chassis. The old ones are on the PSU, and I think I'm going to buy some to be mounted on the chassis anyway. I think they are M6 so you could add something like spikes or Isonoe footers later.
I'll have pics when it's ready on Saturday. Color is off a bit no doubt, better pics to come. He made a custom wood tonearm mount:
https://drive.google.com/folderview?id=0B4DCwTNWPBykRC0yeUtjX3dxQW8&usp=sharing
doctorcilantro
« Reply #3 on: 27 Jan 2014, 02:09 pm »
xsb7244
« Reply #4 on: 27 Jan 2014, 06:44 pm »
doctorcilantro,
Thousands and thousands own the Technics 1200 including me.  Some have the KAB mods to improve the stock turntable.  In your experience do the Roy L Craftmods improve the stock Technics turntable?  Do not comment about the Roy L Craft mods unless you have listened to them.
doctorcilantro
« Reply #5 on: 28 Jan 2014, 07:18 am »
It's the worst table I have ever heard...  :green:
There are aftermarket platters and mounting plates for a reason. Roy's dampening makes a big difference with regard to rumble and provides a blacker background. The wooden arm mount provides for better tone and overall sound quality, no metal ring like the metal plate alone.
doctorcilantro
« Reply #6 on: 4 Feb 2014, 09:45 am »
