A battery question
0 Members and 1 Guest are viewing this topic. Read 802 times.
charmerci
A battery question
« on: 8 Dec 2013, 04:00 am »
I figured this would be the best place to get an answer.
I'm having a disagreement with my local post office.  :roll:
I tried to mail a camera lithium battery. They said I couldn't. I've even asked two clerks on two separate occasions and they both say the same thing - you can mail a battery attached to the item but not the battery alone.
I say they are far more likely to overheat while attached to the item than just the battery by itself.
Who's right?
rodge827
Re: A battery question
« Reply #1 on: 8 Dec 2013, 04:06 am »
Had the same issue once.
I thought the same thing as you, but hey it is the Post Office.  :roll:
Put it in a padded envelope and take it to a different PO and drop it in the outgoing chute...worked OK for me.
Chris
