soldLenco L75 turntable
0 Members and 1 Guest are viewing this topic. Read 1817 times.
J-Pak
« on: 7 Dec 2013, 12:06 am »
Up for sale is a Lenco L75 in very nice condition. A conservative 6/10 on the Audiogon scale. I purchased this from a member of Lenco Heaven and it is in perfect working condition. The one flaw is there is a crack in one of the dust cover hinges. The dust cover (smoked brown color) also has lots of swirl marks on it. These usually do not come for sale in this condition.
If you are interested in these Lencos I'm sure you know they can be truly outstanding once they are in a heavier plinth with better motor isolation. This was my plan, but I gave up my shop/wood working tools when we moved to our new house. Arthur Salvatore's thoughts on his Jean Nantais Lenco, which replaced his Forsell Air Force turntable: http://www.high-endaudio.com/RC-Lenco.html
sold
Shipping details- I will make sure it is well packed, sent via UPS or Fedex insured. It will be shipped in two separate boxes. The tonearm will be removed. The motor will also be packed separately as LH advises.
Pictures: removed
« Last Edit: 18 Jan 2014, 01:17 am by J-Pak »
raneypdx
Re: Lenco L75 turntable
« Reply #1 on: 7 Dec 2013, 12:51 am »
Hi,
Does this unit have the 50Hz or 60Hz motor and spindle?  Does it have a metal or plastic idler wheel?  Can you provide a picture that shows the unit from underneath?  Thanks.
Bob Stark
« Reply #2 on: 11 Dec 2013, 11:11 am »
Does the turntable run at each speed correctly or does it need cleaning and adjustment?  Not including the tonearm, do things work properly?
Bob
J-Pak
« Reply #3 on: 13 Dec 2013, 05:08 am »
60 Hz motor/spindle (shorter), metal idler wheel.
It runs fine, but the motor has not been removed and cleaned. You will need to do this for lowest noise/smoothest operation for the best sound quality.
pictures removed
dknywinnie
  • Music for Life
Re: soldLenco L75 turntable
« Reply #4 on: 18 Jan 2014, 01:17 am »
PM sent
