What amp do you use with your TRL Dude Preamp?
0 Members and 1 Guest are viewing this topic. Read 1031 times.
ThomasKott
« on: 5 Dec 2013, 03:05 am »
Hi, I just bought a TRL Dude preamp and need suggestions on what amp(s) to match with it?  What combination do you have and what works well with this pre-amp?  Any details you can provide are much appreciated!
I'll be running a Meitner MA-1 Dac into the Dude.  Speakers are the Salk HT2-TL's.  My amplifier budget may go up to $9,000.  Hopefully I'll find something used to stretch the level of performance I can achieve in my system.  I'm open to SS, Tube, or hybrid amp.  I want to make sure it is very detailed and open sounding.
Geardaddy
Re: What amp do you use with your TRL Dude Preamp?
« Reply #1 on: 5 Dec 2013, 09:19 am »
Paul at TRL makes some of the best push pull tube amps around.  I would ask him about those.  I used his ST-100 with a Dude.... 8)
