0 Members and 1 Guest are viewing this topic. Read 5346 times.
I'd go with either the Denon D-110 or if you can find one the D-160. For the $ spent they are both excellent deals. I had both so know where of I speak. I also did use for awhile the Benz Ace L and liked it also but you had to have a MC preamp whereas the Denon's don't need it. Good luck!
I ended up putting a Grado Green1 cartridge on my Christmas wish list. I also added a brush and a shure force gauge. I already have a spin clean. I have been using MOFI sleeves after I clean the LPs.
Here: http://www.youtube.com/watch?v=0hgdyWXUFqAAt the end of the video, he forgot to set the anti-skate dial when he was done, so remember to set that to 1.5 (anti-skate dial is supposed to match the gram weight you are tracking your cartridge at).Wayner
