Cornet - 12AX7 tubes
0 Members and 1 Guest are viewing this topic. Read 2167 times.
Laudanum
« on: 4 Aug 2004, 11:42 pm »
Wondering if the 12AX7 filaments are connected in series or parallel in the cornet?
Thx
GRD
« Reply #1 on: 5 Aug 2004, 01:27 am »
I would think they are parallel (6.3V source, pins 4 and 5 to 9).  But I tried a 7058 in place of the 12AX7 and it seemed to work.  Got the 7058 in a bunch of used tubes which were 12AX7 or equilavent.  Later read up on the tube and learned it was wired for 12V only.  I was left wondering if the 7058 was mislabeled.
Laudanum
« Reply #2 on: 5 Aug 2004, 01:52 am »
Had to be mislabeled or filaments are series because I believe the 7058 would not operate otherwise.  But that was why I was asking  :)
GRD
« Reply #3 on: 5 Aug 2004, 02:07 am »
O.K.  I just looked at the tube.  It's an RCA (printing clearly visible) and very clearly labeled "7058".   And it works.  You might be on to something as the 7058 is a sleeper so I hear.
Grant
