0 Members and 1 Guest are viewing this topic. Read 5708 times.
Remember that power line filters are problem solvers. If you don't have the specific type of problem that the filter is designed for, then the filter adds nothing to your power quality. Ham radio operators have an advantage here. Their receivers can measure the interference frequency and level, then they can add a filter and re-measure it's level.
You can work with that. X caps across the back of each, .1uf and 1uf. Then use a 17a choke at the begining if your load isn't high. Another option is to make an inline unit to that. Inside of containing a few options ( like a choke and super-cap setup, it'd be a box the size of a DAC or so)The best, while keeping that box, would be felix's inline after it. The advantage here is that the componets will feed less noise to eachother. Feel free to PM me if any of this makes you uncomfortable. Stay safe with line voltages.Oh and your ground wire looks less than 12ga. Are those sockets isolated ground? If so switch to star grounding.
The ground wire should only be starred IF the sockets have isolated ground. You can check this way,1. unplug everything from the unit.2. connect multimeter to ground pin on IEC or ground pin socket, and the other end touch it to the back strap, screws holding socket to case, or exposed metal case itself.3. if there is a connection between the two, you don't have isolated and can skip star grounding. Un-isolated receptacles "star" at the case, but the daisy chain is to allow a more direct, high current, low resistance, path back to the breaker panel. Starring at the case isn't an upgrade; I don't specifically recommend it for optimal use, but it works.
