0 Members and 1 Guest are viewing this topic. Read 3682 times.
For one, I cannot find a way to search for iTunes songs that are hi-res. (There's no Smart playlist for Sample Bit Rate, that I can see....you can sort of do it by searching for very high Sample Rates, but not very well.)
The bit depth is unimportant, as who has 16-bit/96KHz or 16-bit/192KHz files?Steve
After your comments I re-examined and realized that these files are 16-bit audio files but all have high sample rates. They are also all ALAC conversions that were done many many years ago - I suspect the files or perhaps the originals somehow got corrupted along the way, or perhaps whatever converter I used back then was not configured properly.
Back to OP - for Remote, I understand that it's simply a front end - any editing in iTunes has to be done on the computer itself. Is that correct? It's another point of contention if I have people over etc. - I don't think I can make on-the-fly playlists from Remote, so I need to go through the annoying process of actually doing it on the computer.
the problem will, again, be making it simple to access them. Are you going to have some sort of keyboard and mouse by each TV as well? That's very inconvenient to use - computer operating systems are not designed to be operated from a distance.
For streaming movies and musics (non-hi-res), I would suggest that a Roku 3 with Plex attached to each TV would get you a cheaper solution that is also much simpler and easier to control with a point-and-click interface, which is what you normally want in the TV format.
I used to use Remote, but it is very limiting. I now control my MacMini using Screen Share to my 17" PowerBook. Much betterdave
I would highly recommend the Roku
If you have lots of your own ripped movies (as I do), then the Roku is better.
