FS: Conrad Johnson CA-200
0 Members and 1 Guest are viewing this topic. Read 1231 times.
polyglot
« on: 28 Nov 2013, 12:37 am »
PRICED TO SELL AT $3,150
For your consideration is the famous Conrad Johnson CA-200 Control Amplifier in great condition that works perfectly. This unit, original US version, was bought from a dealer, plays flawlessly and has never been repaired, nor modified in any way.
It comes with printed manual, remote. I do not have the original box but will package well
The CA-200 embodies circuitry similar to the Premier 350 Power Amplifier with front end volume control and input switching. It delivers an end to end zero feedback design with superlative detail and dynamics. This is a must for audiophile who wants a good deal and all in one chassis.
Specifications
Power: 185 watts per channel RMS both channels driven into 8 ohms from 20Hz to 20kHz at no more than 1% total harmonic distortion or intermodulation distortion.
Sensitivity: .32Vrms to rated output
Small Signal Distortion: less than .1% at mid-band
Frequency Response: 20Hz to 20kHz +0/-.5dB
Hum and Noise: 102dB below rated output
Phase: speaker output is phase inverted, preamp output is phase correct
Input Impedance: varies with level control setting, 12k Ohms minimum
Dimensions: 15.5"D x 19"W x 3.315"H
Net Weight: 38 lb net; 45 lbs shipping
NO TRADES - thanks.
« Last Edit: 3 Dec 2013, 04:54 am by polyglot »
polyglot
Re: FS: Conrad Johnson CA-200
« Reply #1 on: 3 Dec 2013, 04:53 am »
bump, great baby Premier 350
