Another Thanksgiving week sale.
0 Members and 1 Guest are viewing this topic. Read 5433 times.
Danny Richie
« on: 26 Nov 2013, 05:59 pm »
Okay, it is kind of like a Black Friday sale, but last until they are gone.
I still have some X-LS Classic cabinets left. They look just like these pictured below except they are cut for the Classic dome tweeter.
I have 4 pair left in unpainted MDF and 3 pairs left in black.
I am blowing them out. $40 a piece for the MDF ones and $50 a piece for the black painted ones.
Then you can order a complete X-LS Classic kit for $109. That is for everything pictured below.
Call to order to get this deal: 940-592-3400
remember this sale is good until they are gone. So you better get them while they last.
Donald
Re: Another Thanksgiving week sale.
« Reply #1 on: 26 Nov 2013, 08:03 pm »
OK Danny I am in for a black pair, although I have never done a kit before. Have no idea where the crossover will mount, or  if I need to line with No rez, polyfill, etc.  Will need direction.
Reason I am purchasing these, wish to see how they compare to the little Pioneers. Not sure what or where i will put them, but not a lot of
cost.
Will call after post.
Danny Richie
« Reply #2 on: 26 Nov 2013, 09:15 pm »
cost.
You'll like this kit Don. And building it out is a piece of cake. This one is really at a beginner level of difficultly.
And you might want to spring for a sheet of No Rez. No Rez will tighten up the bass response and give you a cleaner lower vocal region.
Donald
« Reply #3 on: 26 Nov 2013, 09:24 pm »
Sounds like a plan. However, I am below the beginner status, more like Noob would be closer to my ability as far as kits go. :duh:
« Last Edit: 26 Nov 2013, 10:41 pm by Donald »
aemarcha
« Reply #4 on: 26 Nov 2013, 10:24 pm »
Danny,
  Ron Joyner is going to build me a set of XLS encore with the piano black cabinets from PE.  How do these compare?  Is the tweeter cut-out too large for the Encore tweeters?
Danny Richie
« Reply #5 on: 26 Nov 2013, 11:04 pm »
Danny,
Lining the cabinet with No Rez or not will have a greater effect on the sound than any differences between the two cabinets. I don't like the quality of the MDF in the PE cabinets compared to US made MDF, and I don't like the brace running up and down. That can cause a problem. I cut the center of the brace out when I use those boxes. After cutting out the center of the brace lining the cabinet with No Rez fixes those issues.
The tweeter hole is larger on the X-LS Classic. But I do have some Encore tweeters with X-LS Classic face plate sizes just for upgrading them. So you could use these boxes with the Encore kit if I supply the larger face plate Encore tweeters.
« Reply #6 on: 26 Nov 2013, 11:42 pm »
I mentioned this a while back in another thread...  I believe the  encore tweeters  use a larger  through hole  than the classics.
When I built the encores,  I originally  had built for the classics .  Changed my mind when I actually ordered the kit and go tthe Encores with the classic face plates.    I eneded up having to glue a plug in the  original Classic cutout   so I could re route  a larger through hole (3.125 Encore vs 2.75 Classic)
Just something to be aware of
-jay
Danny Richie
« Reply #7 on: 26 Nov 2013, 11:50 pm »
You can make the through hole larger with your router without having to make a jig for it. You can do it by hand just going around the inside edge of the through hole until it is opened up large enough. I personally do it with a hand held die grinder. Even if it is a little off the big face plate of the tweeter will cover it all and the gasket will seal it.
« Reply #8 on: 27 Nov 2013, 12:24 am »
That'll work too
Think if I were doing it that way I'd  use the die grinder as well,  one slip with the router and ... DOH   :o :lol:
-jay
kc8apf
  • Are you sure what side of the glass you're on?
« Reply #9 on: 27 Nov 2013, 06:07 am »
That price is too good to pass up.  I haven't finished the X-LS Classic I'm currently building but went ahead and ordered another classic kit and an unpainted cabinet.  The 2nd set together with a X-CS and 12" servo sub will be a wedding gift for a good friend.  It's going to be a busy winter.
djslash
« Reply #10 on: 27 Nov 2013, 01:28 pm »
Amazing value. Thinking of it, but need to find out first if I can shipp this set to Europe with my other purchases (x-static voce omni kits).
Danny Richie
« Reply #11 on: 2 Dec 2013, 05:32 pm »
Black cabinets are gone. Three pairs of unpainted MDF left as of morning 12-2-13.
Donald
« Reply #12 on: 3 Dec 2013, 08:51 pm »
Danny,
Did you ever have a chance to figure out shipping for me (32136) on the kit?
Don
Danny Richie
« Reply #13 on: 3 Dec 2013, 09:16 pm »
Danny,
Don
Sorry if I overlooked you Don. $21 shipping on a kit. $38 shipping on the cabinets.
Danny Richie
« Reply #14 on: 3 Dec 2013, 09:20 pm »
Reason I am purchasing these, wish to see how they compare to the little Pioneers. Not sure what or where i will put them, but not a lot of cost.
Actually a guy brought in a pair of those last week. They measured pretty smooth. The spectral decay was real clean. The impedance was a bit high on the tweeter end, and had a slight resonance down low. Not bad. The cabinets were pretty hollow and resonant though.
They sounded pretty good too, but as soon as he heard the X-LS Encore he mentioned that he might be able to return the Pioneers. He bought a X-LS Encore kit, Sonicaps, No Rez, and tube connectors.
Donald
« Reply #15 on: 4 Dec 2013, 03:19 pm »
Thanks Danny. When can I expect shipment on these little puppies?
Danny Richie
« Reply #16 on: 4 Dec 2013, 04:07 pm »
I can ship the day you order unless you order late in the day. Just call to order.
kc8apf
« Reply #17 on: 21 Dec 2013, 05:54 am »
I received my cabinets a few days ago but didn't get a chance to look at them until tonight.  There are shallow holes in the bottom for feet.  Do you know what size and style of insert they are for?  The 1/4-20 inserts I have were a bit small.
Danny Richie
« Reply #18 on: 21 Dec 2013, 06:13 pm »
They are drilled for these: http://gr-research.com/floorspikes-brasssetof4.aspx
Or these: http://gr-research.com/floorspikes-chromesetof4.aspx
