Corkboard wall coverings as room treatment?
0 Members and 1 Guest are viewing this topic. Read 1767 times.
geowak
« on: 25 Nov 2013, 05:18 pm »
Does corkboard wall covering act as a decent acoustical room treatment? Has anyone used this?
Ethan Winer
  • Audio expert
Re: Corkboard wall coverings as room treatment?
« Reply #1 on: 25 Nov 2013, 06:56 pm »
In a word: No. Cork does absorb some, but not much. And the cork material I see is too thin to absorb at all at lower frequencies. The goal of room treatment is to absorb uniformly over a wide range of frequencies, not just at mid and high frequencies.
--Ethan
rodge827
« Reply #2 on: 25 Nov 2013, 07:22 pm »
You will have to go with much thicker about 1" to get any kind of result, and YMMV.
It can be purchased at McMaster-Carr:  http://www.mcmaster.com/#cork-insulation/=pjau1r
BTW if you go with cork wall covering it is easy to install.
Prep the wall properly with a good wall covering primer and use a heavy duty clear wall covering adhesive at full strength (do not thin it down).
Try not to get any adhesive on the face, and keep a lot of sharp blades handy.
Chris
