SOLD : Bruce Moore Companion III two channel preamplifier w/Auricaps
0 Members and 1 Guest are viewing this topic. Read 2874 times.
Beatlebum
SOLD For sale here is an excellent Bruce Moore Audio Design Companion III two channel tubed preamplifier in Near Mint condition. The Companion III is less than 2 years old and purchased from an authorized Bruce Moore Audio retailer. Retail price on this preamplifier is over $4,000.00
The Companion III, totally configured for RCA (single-ended) inputs and outputs, comes with one main output set, a tape output, two CD inputs, tuner input, tape input, and auxiliary input. There are two attenuators (volume controls), one for each channel; an input selection control; and an off-mute-on control.
Tubes are two 6922s, two 12AU7s, and a fifth 6922 for the power supply. All tubes save the power tube are operated in triode mode. This means that only 1/2 the tube is in use at any given time. When a tube shows signs of wear, it can be moved to the other channel, which utilizes its other half. This results in tubes lasting twice as long.
Specifications:
● Gain: 23 dB
● 5 Line Inputs, Main Out and Tape Out
● Frequency Response: 1 Hz to 500 kHz +0,
    -1dB
● Maximum Output: 25V RMS
● THD: < .03% 2V RMS Out
● Input Impedance: 75K Ohm
● Output Impedance: 500 Ohms
● Noise: -98dB below 2V RMS output
● Absolute Phase: Non-Inverting
● Tube Complement: Three 6DJ8/6922, Two
    12AU7
● Power Consumption: 30 watts (detachable
    line cord)
● Dimensions: height = 3.6" (79 mm), width =
    16" (381mm), depth = 12" (241mm
Shipping is by the Buyer. Local sale in the NW Indiana/Chicagoland area is welcome.
Paypal fees are by the buyer.
Check my excellent feedback on A-gon under the same moniker and buy with confidence.
Thanks for looking!
« Last Edit: 27 Feb 2014, 07:59 pm by Beatlebum »
Beatlebum
Beatlebum
Bump once more! :D
Beatlebum
Price reduced to $2100 or Best Offer!
Beatlebum
Price reduced to $1700 or best offer.
