BP26DA Static Discharge
0 Members and 1 Guest are viewing this topic. Read 2418 times.
rawbcca
« on: 24 Nov 2013, 12:27 pm »
James have you ever heard of this happening?
I went to turn on my BP26DA When my finger touched the MUTE/NORMAL toggle I heard the distinct crack of a static electrical discharge.
Without even toggling the switch the unit turned ON. At the time the selector switch was set to DAC and now the DAC no longer works?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BP26DA Static Discharge
« Reply #1 on: 24 Nov 2013, 12:38 pm »
Gee I have not -  try unplugging and replugging the power cord in the wall and see if that helps.
james
rawbcca
« Reply #2 on: 24 Nov 2013, 12:50 pm »
Thanks James, That did the trick.
Speedskater
  • Kevin
« Reply #3 on: 24 Nov 2013, 01:24 pm »
The old Soundstream digital recorders would do that.  What kind of logic IC chips do you have on the switches?
« Reply #4 on: 24 Nov 2013, 01:32 pm »
Hi
Email Mike Pickett on that one - its above my pay grade  :scratch:
[email protected]
james
rollo
  • Rollo Audio Consulting -
« Reply #5 on: 24 Nov 2013, 03:58 pm »
  It appears you have static build up in your home. try a steel washer attached to a say 12ga wire and connect wire to ground [ use a banana plug into ground hole of receptacle ]. Before you touch the unit grab on to the washer and ground yourself. Will never happen again. :thumb:
charles
stonedeaf
« Reply #6 on: 7 Jan 2018, 04:00 am »
Not a DA model - but my Line level BP26 has been getting hit by a pretty good static charge every time I touch it -most of the time -this does nothing - but randomly it either mutes or unmutes the pre-amp. Doesn't seem to be doing any harm -just odd. ?
Elizabeth
« Reply #7 on: 7 Jan 2018, 06:14 am »
I have had a BP-26 for over 7 years.
Never have had a static problem.
Though I did with a TT a little bit a few years ago.
I am always barefoot in the house. The carpet I have no idea what it is made of?
Probably just nylon.
And I do not do a lot to prevent low humidity in Winter. (6F outside right now)
I would guess the static problem is some combination of shoes/socks material carpet is made of.
And low humidity.
The low cost humidifier is the shower. Take lots of showers.
stonedeaf
« Reply #8 on: 7 Jan 2018, 06:43 am »
I'm a few miles away from Elisabeth - so pretty much same weather. I have noticed in general that if I'm in my stocking feet this seems to be less of a issue. I don't hear it thru my speakers -so suspect the static discharge is simply tripping whatever logic chip controls the mute relay. The air certainly is very dry at this point. I have the older Power Supply (No HIP) -not sure if this makes the BP-26 more or less vulnerable to switching when hit by static discharges ? This definitely falls into the  no harm/no foul category - just strange.
TJ-Sully
« Reply #9 on: 8 Jan 2018, 01:34 am »
same thing here....
I have a BP20 preamp. Almost everytime I touch the volume knob, a static shock causes the preamp to stop working. After the shock, the preamp and power supply indicate a red LED light. Gotta turn it off and back on again to get it working.
Just started happening a few weeks ago....when the weather got super cold and dry.   I'm in eastern canada.
Looking for advice, I emailed Mike at Bryston. He got back to me right away, and simply advised to touch another component first before the preamp - say the DAC or BDP.  it works everytime now...that is when I remember not the grab the volume knob first!
TJ
« Reply #10 on: 8 Jan 2018, 01:56 am »
charles
It will dismiss static. Maybe the static was build by the user body, mainly clothes not by the equip.
« Last Edit: 8 Jan 2018, 03:24 am by FullRangeMan »
stonedeaf
« Reply #11 on: 8 Jan 2018, 02:17 am »
In my case -the static discharge only trips the mute circuit on or off. It's pretty easy to just lean to the right and manually shift back to whatever mode I want the pre-amp to be in. Have never had it lock up and have to do a hard boot. For me - very minor problem. Worth reporting just so if things shut down after a zap for some one else - look at the mute relay LED .
Speedskater
  • Kevin
« Reply #12 on: 8 Jan 2018, 05:15 pm »
same thing here....
TJ
Decades ago, I was running the recording equipment for a Telarc recording. Over night the temperature had dropped a lot.  I was cueing up a tape on the SoundStream recorder (I said that it was a long time ago) when I touched one of the switches the tape recorder stopped!  So I touched the chassis with one hand and then the switches with the other.
Back at my day job, I investigated why it happened. Some of the old 74LSxxx digital chips were sensitive too static on their input pins and those pins were connected to panel switches.
rpmartins
« Reply #13 on: 8 Jan 2018, 08:00 pm »
Sometimes I get a discharge when touching the amps. It´s static and only happens when I´m wearing wool.
There was a time I can change sources on my cyrus3 fronte panel without even touching the face plate.
