Why do I now need caps server ??
0 Members and 1 Guest are viewing this topic. Read 2305 times.
this_is_vv
« on: 23 Nov 2013, 10:12 am »
Just saw this
http://www.frys.com/product/7831669?source=googleps&gclid=CLDkrJPV-roCFaxr7AodNiwAqQ
Tell me why I now need caps server this is i5
DTB300
Re: Why do I now need caps server ??
« Reply #1 on: 23 Nov 2013, 01:40 pm »
These work great with an iFi USB Power your favorite DAC and Win 8
TJHUB
« Reply #2 on: 23 Nov 2013, 01:44 pm »
Personally, I'd never build a computer music server without a Paul Pang USB output card.  A very large portion of the magic comes from just it alone.
chip
« Reply #3 on: 23 Nov 2013, 03:36 pm »
If you are only doing music i5 is overkill. I would look for the Nuc i3.
http://www.frys.com/product/7578706?site=sr:SEARCH:MAIN_RSLT_PG
krikor
  • Initiative comes to those who wait.
    • AudioSnoop.com
« Reply #4 on: 23 Nov 2013, 04:10 pm »
Fanless? Also, I think I was able to put together my CAPS for quite a bit less... assuming you don't need that extra horsepower.
this_is_vv
« Reply #5 on: 23 Nov 2013, 10:03 pm »
I don't see anywhere caps are less then 600??
krikor
    • AudioSnoop.com
« Reply #6 on: 23 Nov 2013, 10:35 pm »
I built mine for $370 which includes a $150 hard drive and 8GB of RAM, both of which I do not think are not part of the barebone systems linked to above. Mine is also totally silent with the SSD and fanless motherboard.
http://www.audiocircle.com/index.php?topic=113488
Of course, the one I built has a lowly Atom processor, but that is all the horsepower I need for an audio-only CAPS.
firedog
« Reply #7 on: 24 Nov 2013, 02:01 pm »
A dual core ATOM chip will do fine for audio unless you want to DSP or resampling on the fly. In that case you need the i5 or i7.
The downside to the NUC box is very limited expandability. For instance, if you want one of the upmarket USB cards designed for audio, you're out of luck, I think.
The PC in the link is also not fanless (active fan heatsink); the CAPS is.
jtwrace
    • TIPP YouTube Channel
« Reply #8 on: 24 Nov 2013, 02:21 pm »
Can you provide a link to them?
srb
« Reply #9 on: 24 Nov 2013, 02:36 pm »
Sorry Jason, couldn't resist.  ;)
http://lmgtfy.com/?q=paul+pang+usb  (4th link)
AUDIO GRADE USB 3.0 PCIE CARD page
http://ppaproduct.blogspot.tw/2013/07/audio-grade-usb-30-pcie-card.html
jtwrace
« Reply #10 on: 24 Nov 2013, 02:39 pm »
Thanks.
At least it's only $129 assuming it actually does something.
mav52
« Reply #11 on: 24 Nov 2013, 02:57 pm »
Just saw this
I wonder if Intel actually makes this,   I noticed HMDI 1.4 so whomever it is has the license  , well I guess they really do http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-kit-dc53427hye.html
azhtnut
« Reply #12 on: 25 Nov 2013, 04:18 am »
I spoke to a Fry's salesperson today about these units.  He said you need to add memory, a SATA drive, and an operating system software to these units.  That would add $300 - 500 or more if true.  Can anyone confirm whether that's the case?
sts9fan
« Reply #13 on: 25 Nov 2013, 04:30 am »
That is the definition of "barebones". Yes.
