0 Members and 1 Guest are viewing this topic. Read 10532 times.
Hi Guy13This means alot of things if you think about it!one of the things is:Sealed loudspeaker systems are best at low loudness levels.Ported loudspeaker systems are best at high loudness levels.For home use sealed is better.For club use ported is better.of cource you can use any speaker type anywherethis was just a comparison between these two...hope this helps, if not, no worries...
Push-pull is the way to go. Only the best loudspeaker manufactures build them......
Who's designing? They all can sound good. I actually like OB, too. Straight sealed can be a little constrained sometimes. I tend to prefer a dynamic sound.
This thread is confusing as hell
Ported is better at low volume because they are a little more efficient than sealed.
The premise of the original query is questionable. The thread can't go anywhere but get more confusing. Vented boxes and sealed boxes are apples and oranges. Assuming you could declare one better than another is not possible.Dave.
Ported are the same efficeincy as sealed, the box only affects low frequencies. A vented box will generally provide more gain at the lowest frequencies.dave
Best (sealed vs. ported) also depends on application. Realize that we're only speaking of 300 Hz (at most) on down.I prefer sealed due to roll off matching with room gain, less out of phase (back wave) signal escaping (as with most designs much can still come out through the cone or simply by contacting the cone and smearing the sound), and they seem to integrate better with a sub. I don't prefer sealed due to reduced efficiency and dynamics (both issues that adding a sub helps to address, but that sort of avoids the whole question here).Note that classic ported designs from the 70s/80s added a mid-bass boost so that that deep bass levels would stay that much higher (works great for rock).There are a myriad of options for producing better bass, but there is no perfect speaker, just trade offs for taste, opinion, etc.
"A vented box will generally provide more gain at the lowest frequencies."yes at the high power levels...correct me if i'm wrong?
At all power levels.An important thing to remember is that as the power levels change so do the T/S levels. They change in a such a way that sealed boxes tend to remain constant whereas typical vented boxes will mpve in and out of tune.dave
