Old stock tubes for sale - all fully Amplitrex tested!
0 Members and 1 Guest are viewing this topic. Read 1328 times.
Ericus Rex
Cleaning closet tube sale!  All tubes sent to TC tubes (www.tctubes.com) and tested on their state of the art Amplitrex tester.  TC’s data sheet included with all tubes.  No shorts, no high grid leakage.  Unless otherwise stated, tubes are in white boxes.
6L6   100% = 5200Gm
   Tight matched pair of JAN/Philips 6L6WGB – 5400/5600 Gm (104%/108%), very strong with original JAN white boxes - $60/pair
   Single as above – 4150 Gm (80%).  Also with orig box – $15
6SL7   100% = 1600Gm
   One JAN /Philips ECG 5691 – 1100/1100 (69%).  Balanced sections, original box - $10
EL34   100% = 5000Gm
   Single Siemens/RFT EL34 – 3960Gm (79%).  No lettering. $20
6DJ8    100% = 12,500Gm
   Matched pair of Sylvania 6DJ8.  One labeled “JAN Sylvania” the other “Westinghouse”  10,200/9800 (82%/79%) & 9800/11,000(79%/88%).  Westinghouse in original box.  $20/pr
   Single Telefunken 6DJ8.  Good lettering with ‘diamond’.  10,800/10,600 (86%/85%).  $30
   Single Amperex 6DJ8.  No lettering, with ‘X’ seam at top. 7800/9600 (62%/77%).  $10
   Single Amperex Holland ‘Bugle Boy’ 6DJ8. Fair lettering, ‘X’seam. 12,600/12,200 (101%/98%).  One section tests a little gassy.  TC thought this would clear with use as the other section (within the same tube) tests low gas.  Could also be a testing anomaly.  $30
   Single Amperex Holland ‘Bugle Boy’ 6DJ8.  Excellent lettering, ‘X’seam. 9800/8000 (79%/64%).  $10
12AX7   100% = 1600Gm
   Matched pair Sylvania 12AX7.  One labeled “Sylvania” the other “Philco”.  1800/1900 (113%/119%) & 2200/1700 (138%/106%).  $20/pr
   Single Sylvania 12AX7.  Labeled “Baldwin”  1400/1700 (88%/106%).  $10
   Single Raytheon/Japan 12AX7.  1400/1500 (88%/94%).  $12
12AU7   100% = 2200Gm
   Matched pair Tung Sol 12AU7.  Fair lettering.  Tight match and balance at 2000 (91%) all 4 sections.  One original box, one CEI box.  $60/pr
   RCA 12AU7.  Fair lettering, orig. box. 2200/2200 (100%/100%) $12
        RCA 12AU7.  Fair lettering, orig. box.  1500/2000 (68%/91%).  $8
        Loosely matched NOS pair of Ei ECC82 (12AU7).  Good lettering, orig boxes.  2200/2400 (100%/109%) & 2600/2800 (118%/127%).  $30/pr.
        Single Ei as above.  1600/1400 (73%/64%).  $6
        Matched pair of GE 5814 (12AU7).  No lettering.  2200/2200 (100%/100%) & 2000/2000 (91%/91%).  $40/pr
        Single RCA 12AU7 Clear top.  No lettering.  2400/2300 (109%/105%).  $10
        Single Raytheon 12AU7 Blackplate.  Labeled “Lowry”.  2000/1800 (91%/82%).  $12
     Single “Baldwin” Japan 12AU7.  Good lettering.  1800/2000 (82%/91%).  $12
     Single Tung Sol 12AU7.  Poor lettering.  1800/2000 (82%/91%).  $12
     Single Tung Sol 12AU7.  Excellent lettering, orig box.  1600/1400 (73%/64%).  $8
PM me your selections and address and I’ll work out cheapest shipping option for you.
Eric
« Last Edit: 1 Mar 2014, 03:39 pm by Ericus Rex »
Ericus Rex
Re: Old stock tubes for sale - all fully Amplitrex tested!
« Reply #1 on: 23 Nov 2013, 02:47 pm »
If you need pics I'm happy to do so!
Ericus Rex
« Reply #2 on: 25 Nov 2013, 05:02 pm »
List updated.
Ericus Rex
« Reply #3 on: 5 Dec 2013, 12:10 pm »
bump
Ericus Rex
« Reply #4 on: 26 Dec 2013, 01:29 pm »
Bump!
Ericus Rex
« Reply #5 on: 1 Mar 2014, 03:40 pm »
List updated.
