0 Members and 1 Guest are viewing this topic. Read 8896 times.
Bob,Is your cartridge metal bodied? I've found that metal bodied carts require far more emf reactive crystals than non-metallic bodied carts. On the 3 non shielded carts I've done this with, Miyajiima Mandake, Dynavector DVT Xv-1t and Cardas Ruby Heart, the maximum amount of crystals (which are less reactive than your quartz family ones) have been 40 milligrams. The results have been anything but subtle, more like getting smacked upside the head with a 2 x 4, but in a good way....FWIW,Paul
I don't want to discount possible EFI/RMI, electrical, etc. interactions of certain types of nearby materials, maybe especially more possible with some cartridges than others. However, with the size of the applied crystals here, there is a very significant increase in arm/cart effective mass that is being introduced. In today's average case, that CAN be a pretty good thing. Many tonearms are designed on the light side, such that they might work acceptably well with cartridges that have a variety of compliance ratings and masses. Chances are good that many out of the box cart/arm combos result in mass-spring natural frequency responses in the region of maybe 20-30 Hz. That will result in a turntable that tracks well and will produce acceptable levels bass reproduction for speaker systems that may start rolling off in a typical 40-30 Hz or so region.More accurate recovery of lower bass, clarity and stability of image, etc., etc. will all be improved significantly if the tonearm/cart effective mass and cartridge compliance can be more carefully matched to bring that natural frequency more toward the classic recommendation of approx 9-12 Hz. (as low as possible without introducing record warp tracking problems)I suggest investigating the numbers for your arm/cart to see what the natural frequency might be. Chances are that adding a little mass could be just the direction you might want to go. Of course, experimenting until you get close to having tracking problems is also allowed. Happy A-B-ing!!Cheers, John
Fellas, I would love to try a non-commercial alternative. Can you recommend something I can do on my own? I'm serious . . no jive. LW shouldn't mind terribly given my income level.
