Can a Bryston SP 2 Surround Processor be used as a 2 channel preamp ???
0 Members and 1 Guest are viewing this topic. Read 4081 times.
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
Can I use a SP-2 as a two channel preamp
would it equal a
BP-6
BP-25
BP-26
BP-17
BP-16
BP-20
Will use it with a 3BSST amp and FS-788 speakers
How much GAIN does it have
  • The Demo is Everything!
    • http://www.bryston.com
Equal a BP25
james
turnovertherecord
What would warranty be left
   DATE 1005
would it cover the digital and analog  or is it all warranty for 20 years from manufacture date with original invoice
How much gain for the 2 channel analog inputs and digital inputs
   DATE 1005
Hi
Looks like a year and a bit left as the SP2 is considered a Digital product and has a 5 year warranty.
The warranty runs from the manufacturing date as that is the only way we can track them.
Not sure on the gain question in digital - analog would be the same as a BP25
james
turnovertherecord
Any one know what the gain would be ????
Mag
Sure it can be used as a 2 channel preamp, but why would you want to when you can listen in 5.1 Neo:6. :P
Not sure of the gain question, that's not something I really understand. Gain as compared to another preamp?
 When I'm not rockin' out the volume knob is usually in the 12 o'clock position and reads 12 on the display. Gain however is more of a factor from the source you are using, different sources have different volume. Like I estimate the Bdp-1 is about 3 db less than when using my computer, which I can adjust the volume output, but I typically have it set about 70%. :smoke:
Grit
  • - Garrett
Hi
james
What is the analog section in the SP3 equal to in Bryston preamps?
BP-17 and preamp section of B135 Integrated amp.
james
Phil A
The unit's specs are in the manual and as noted in another post the equipment hooked to it will have differences
http://bryston.com/PDF/Manuals/300023[SP2].pdf
A/D Conversion: 24-Bit, 48kHz Delta-Sigma
D/A Conversion: 24-Bit, up to 96kHz Delta-Sigma
DSP Engine: TI Aureus
Power Supply: Dual, Linear, Toroidal
Frequency Response: 20Hz to 20kHz +/- 0.25 dB
THD+Noise: Less than 0.006% in DSP modes; Less than 0.0025% in Bypass mode 20Hz to 20kHz at maximum output level.
Signal-to-Noise Ratio: 105dB in DSP Modes; 110dB in 2ch Bypass Mode ; 22kHz bandwidth, Ref. 1kHz at maximum output level
Input Level: 2 Vrms in DSP modes; 4 Vrms in Bypass Mode
Input Impedance: 50kOhms
Output Level: 8 Vrms (16 Vrms Balanced) in DSP Modes; 10 Vrms (20 Vrms Balanced) in Bypass Mode.
Output Impedance: 110 Ohms
Bass Management: 2nd Order HP filter(x5), 4th Order LP filter 40 – 200 Hz Cross¬over Freq.
alexone
Equal a BP25
james
...wasn't it equal to a 26????
al.
al.
Some small changes done on the 26
james
Phil A
When I had my SP1.7 (which has the same analog section as the SP2), I compared it to the BP26.  I had compared the SP1.7 to the BP25 before I bought the SP1.7 and could not detect any differences.  The BP26 was a bit more refined.
