0 Members and 1 Guest are viewing this topic. Read 22396 times.
Upate: I spent a lot of time on this today, and never got any of my mics (including a nice pro mic and Centrance Micport PRo USB preamp) to work with Microsoft Impressions Screen Capture. It breaks up like crazy!! I tried every imaginable combination of gain, resolution, bitrates, etc etc. The software seems unstable at best. Argh! So I found a program that looked promising called EZVID, downloaded it late this afternoon, got playing with it, and then tonight tried a couple rough drafts. When I finally felt like I had a decent script in my head I made a 22 minute video...which crashed as it was being, well, encoded I guess, and when EZVID came back up it was blank!!!! It's now 11:30pm and I'm done for tonight. If anyone has a better program, or knows why my stuff crashed, lemme know. I've done the JRiver walk thru now a couple times and feel that it's now the least of my worries.
I'm about to give Windows Server 2012 and the Audiophile Optimizer a try!I'm wondering how powerful the processor needs to be in my audiopc. I have an older computer (Core 2 Duo, SATA) that I'm not currently using that could work, but is there a audible benefit in having a more modern processor (Core i5/Core i7) in the audiopc?
I have a few questions I was thinking of getting/building a CAPS 3 carbon and using the dual PC mode with Jplay and Audiophile optimizer. If I understand correctly I would us my control PC (which has an Esata tower attached to it storing my music) and connect the CAPS 3 to it via ethernet and then the CAPS 3 via USB to my DAC? I use Jriver 19 BTW. So I was reading that Windows Server 2012 sounds best as far as Operating systems go but can it be used on the CAPS 3 with the SOTM USB card?Thanks for any insight.Tony
Yes to all your questions. WS2012 is a great OS and has a 6 month free trial that can be rearmed a few times (i.e extended). It can be used for both pc's. However, if you do the math you realize that the controlpc needs TWO ethernet connections...one for the external ethernet (say 192.168.x.xxx based), one for the private connection to the audiopc (say 10.xx.xx.xx based).
dual pc refers to Jplay (controlpc and audiopc are Jplay terms). No need to do for Jriver only.
