Emerald Physics 100.2SE Special Edition Amplifier
0 Members and 1 Guest are viewing this topic. Read 5764 times.
johzel
« on: 4 Nov 2013, 09:39 pm »
For Sale: Emerald Physics 100.2SE (special edition) Power Amplifier - in Silver Metal Case.  Like new. Awesome sounding amp – especially at its asking price. Asking $1150 $1,000 Firm.  I have two of these available. Shipping from 53574.
The 100.2SE is a 100 watts per channel stereo power amplifier with a class D output stage coupled to a custom Emerald Physics analog power supply. The 100.2SE is an upgraded version of the 100.2 amp. The 100.2SE has both balanced and single ended inputs as well as a mono switch that allows you to end up with a 275 watt mono amp that does over 350 watt peaks.
Specs:
100 watts RMS/ch 8 ohms Digital Amp with custom analog power supply
150 watts RMS/ch 4 ohms
Less than .03% distortion 1 watt
275 watts RMS mono operation Beautiful metal chassis
350 watts dynamic power in mono Extremely efficient (~93%)
Damping: Greater than 300
Dynamic Range: 110dB
3 ohm stable
Input impedance: 60K Ohms XLR/ 30K Ohms RCA
RCA & XLR inputs
Retail: $2,200.00 EACH
Weight: 16 pounds
Made in USA Gain: 30dB
« Last Edit: 13 Dec 2013, 05:21 pm by johzel »
johzel
Re: Emerald Physics 100.2SE Special Edition Amplifier
« Reply #1 on: 17 Nov 2013, 05:45 pm »
Bump  :thumb:
johzel
« Reply #2 on: 29 Nov 2013, 05:39 pm »
Bump for price reduction.  Would also consider trade for tube amp/tube integrated amp.
johzel
« Reply #3 on: 13 Dec 2013, 05:20 pm »
Final Price Reduction.  Out the door at $1,000 - great deal!!!  Thanks.
