0 Members and 1 Guest are viewing this topic. Read 5220 times.
As Jack says having the same type or "brand" if you will, up front is the best way to go.
When you first asked about the Visiun I assumed you have a big room and generous budget. As you live in an apartment and have a limited budget, I might suggest the Visiun would be overkill. My Unifield center matches my VR-33 very well sonically in a medium sized room. It (or something similar) might be compact enough to fit on a shelf inside your cabinet if you could make the space and not have a cabinet door in the way. Jack's setup looks awesome but I bet it is not in an apartment. I agree though that integrating a center channel speaker with a large screen TV is one of the great unsolved problems of our time.
The best way to remedy this if space allows is to not place your equipment rack between your speakers. The center channel speaker can then be easily hung on the wall below the screen...voila
Have you given the VS LCR-4 some thought? Not a Visiun but seeing as all VS speakers, both Unifield and VR, share a voice, it should work.
I don't really want to put my equipment rack in my bathroom or kitchen though - space is a little tight in my apartment to put it anywhere but my living room. Right now the grand ballroom is getting the floors refinished and the solarium can get warm which could be bad for the equipment, and the equipment rack might interfere with the sliding ladders in my library.
