FS: Parasound Classic 2100 preamp - SOLD
0 Members and 1 Guest are viewing this topic. Read 1642 times.
Nuance
« on: 2 Nov 2013, 05:57 pm »
I am selling a Parasound Classic 2100 preamp, black in color.  I am asking $350 for the preamp.  Buyer pays shipping and paypal fee of 3%.  All inputs confirmed working (I accidentally had the preamp set to MM rather than Input, which is why I mistakenly thought Input 1 didn't work).  The preamp is in very good shape.
   - Two channel high end audio preamplifier
         - Front panel jack for portable MP3 player with 12dB auto gain offset to match levels of other sources
         - 7 pairs of line level inputs
         - 1 input pair can be switched for MM or MC phono cartridge with correct input impedance
         - Can add to an existing surround system to upgrade analog 2 channel sound
                 • Connect your 2 channel analog sources to the Model 2100 instead of to your surround receiver
                 • Connects to surround receiver’s L, R, Sub line out jacks & to power amp’s input jacks
                 • Blends seamlessly into surround system, automatic pass-through when turned off
                 • Bypass input can be selected by remote
                 • Creates a mono sub channel output for 2 channel analog sources
                 • Analog bass management, low pass filter, adjustable 20 Hz - 140 Hz
                 • Separate output jacks for full range (large speakers), 80 Hz high pass filtered (small speakers)
         - 2-way RS-232 serial port connection
         - External IR repeater input & loop out jacks
         - Remote control includes discrete codes for Off and On
         - 2 auto turn on modes: AC power, 12v trigger
         - Selecting automatic turn/off defeats the front panel Power button
         - 12V trigger input jack and output jacks, 6’ (2m) trigger wire included
         - Fixed level audio record output
         - Headphone jack with auto mute for line out jacks
         - Motor-driven analog volume control
         - Balance control, bass & treble controls with defeat button
         - Remote handset includes tone on/off button
         - High current power supply
         - Accepts both 115v & 230v AC, detachable IEC AC cord
This unit has been sold.  Thanks!
« Last Edit: 15 Nov 2013, 07:42 pm by Nuance »
REY
Re: FS: Parasound Halo A23 amplifier and Classic 2100 preamp
« Reply #1 on: 3 Nov 2013, 02:03 am »
let me know if the sell does not go trough, please.
Nuance
« Reply #2 on: 3 Nov 2013, 03:36 am »
Will do.  Thank you.
billmcc
Brandon,
Did you check to make sure that the Input 1 switch is set to "Line"? I bought a used 2100 and the setting was set to MM or MC and all I got was static when I connected my Oppo to it. If not give Parasound a call and they might be able to help you.
Bill
Nuance
Brandon,
Bill
Thank you, Bill.  I don't believe I touched any of the switches, as input 1 did work at one point, but I'll verify tonight to be sure.  I'd sure feel silly if that's what happened, though. :)  Thanks!
This post shall also act as a bump: the Parasound 2100 is still available.
Nuance
Re: FS: Parasound Classic 2100 preamp
« Reply #5 on: 14 Nov 2013, 12:11 am »
Bill you're a genius!  Somehow that silly switch got moved to MM rather than Line.  I have no idea how that happened, but you just helped me out big buddy.  Thank you.  Input 1 is fully functional!  The OP has been updated, and the price has risen. ;)
