Looking for a $100 preamp with remote and multiple inputs?
0 Members and 1 Guest are viewing this topic. Read 10970 times.
Doublej
Anything that could be considered the preamp equivalent of the $100 pioneer speakers? Even just not embarrassing will suffice.
Phil A
Re: Looking for a $100 preamp with remote and multiple inputs?
« Reply #1 on: 1 Nov 2013, 12:27 am »
Not a regular deal like the Pioneer but when the Sherbourne merger with Emotiva was announced, they below out their premp, which at one point retailed for $899, then they went to a direct to consumer business model and it was $529 and then they blew them out for $179 including shipping
Phil A
« Reply #2 on: 1 Nov 2013, 02:18 am »
I have no idea how stuff like this sounds but it qualifies as cheap - http://www.mcmelectronics.com/product/555-4051
wushuliu
JohnR
« Reply #4 on: 1 Nov 2013, 09:06 am »
Nice find for C&C :thumb:
Doublej
wushuliu
this_is_vv
wushuliu
« Reply #8 on: 1 Nov 2013, 04:10 pm »
hows teh quality as per your experience....
V
The PGA2310 I have sounds excellent. Clean, clear. The quirks are that it buzzes when first turned on for a few seconds before the relays kick in and the remote works at a narrow angle. But hey $100. Granted I modified mine right away; someone analyzed the board at diyaudio some time ago and found it measured decent enough. The PGA2310 was considered a little better than the 2311 in terms of dynamics, but the 2311s on ebay are the only ones that have mute/treble/bass control option.
JohnR
« Reply #10 on: 2 Nov 2013, 09:32 am »
Depending on where you buy it from, it does have treble/bass control.
http://www.ebay.com/itm/140865254355?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
Um, no, that one doesn't. "there is no MUTE and BAS and TRE functions of this board"
Anyway, they're cheap. Intriguing about the differences of the 2310 vs 2311. I saw an 8 channel one the other day which I might actually get.
Letitroll98
  • Too loud is just right
« Reply #11 on: 2 Nov 2013, 02:49 pm »
I guess I was fooled by the bass-treble-mute buttons on the remote.   :duh:  I suppose these are non functioning buttons on a cheap, one fits all remote?
I have the PGA2310 version. A little quirky but sound is excellent.
Is this the PGA2310 version you have?
http://www.ebay.com/itm/New-version-PGA2310-Stero-Remote-Volume-Controller-Preamp-Assembled-by-weiliang-/141022491269?pt=US_Amplifier_Parts_Components&hash=item20d5987285
Might fit the under $100 requirement better?
timind
  • permanent vacation
« Reply #12 on: 2 Nov 2013, 03:08 pm »
If used is ok I'd look at ebay for an older pre by Yamaha, Harman Kardon, Onkyo or something of that ilk. I bought a Yamaha CX-630 used a few years ago, it worked great. The problem with these used units is the remotes are sometimes missing. Of course, universal remotes are easy to find.
wushuliu
« Reply #14 on: 2 Nov 2013, 04:50 pm »
Of course there's also this awesome piece of kit:
http://www.ebay.com/itm/Pioneer-Elite-VSX-D912K-6-1-Channel-120-Watt-Receiver-/161139953578?pt=Receivers_Tuners&hash=item2584b08faa
Whose merits as a preamp AND and amp have been discussed here at length.
timind
« Reply #15 on: 2 Nov 2013, 05:29 pm »
If size is not an issue this looks like a winner.
I have no use for it but am tempted just to try it.
notany
« Reply #16 on: 3 Nov 2013, 06:49 am »
I ran across this in a review at Affordable Audio.  I have no personal experience with it but it is more to my taste then the other suggestions so far.  At $299 it seems like a good choice although I believe remote adds $200.  Just thought I'd throw another piece of meat into the stew.
http://www.akustyk.com/
http://www.affordableaudio.org/
wushuliu
« Reply #17 on: 3 Nov 2013, 06:57 am »
Well that's 3x-5x the stated budget. Slippery slope. For that money all kinds of options open up like Dodd Preamp, LDR based preamps, etc.
notany
« Reply #18 on: 3 Nov 2013, 07:10 am »
You're right.  It just looked so nice, inside and out.
notany
« Reply #19 on: 3 Nov 2013, 07:26 am »
The Pioneer is a known commodity and adds a DAC, sub out with adjustable x-over, digital room correction and a radio.  Its just, um, it's a surround receiver.  I can't get past that.  Still, it's probably best.
