0 Members and 1 Guest are viewing this topic. Read 5033 times.
sugbob21,If you can bump your budget up to a Decware SE84 Super Zen at $895 or find a used SE84 it would likely be the ideal match for your CSP-3, not to mention your Super 6's. Your CSP-3 may give the Super Zen greater dynamics than running a Super Zen alone. If you are not into high volume listening I think you would have a sublime sounding system. About four years ago I had a higher end 50w/ch gainclone on a pair of hempcone Super 5 Monitors and Deep Hemp sub. It sounded incredible. I then dropped a Decware SE84C+ into the system. The Decware was better across the board except for volume. The gainclone never went back into that system. On another system I had a Decware SE84 Select on a pair of Hoyt-Bedford Type 1's. I don't remember ever hearing Hoyt-Bedford speakers sound so good. Yes, Omega speakers work well with many amp types, but of all the amp types I have heard on Omega's, I find tubes are the best.
