Attenuator wiring question
0 Members and 1 Guest are viewing this topic. Read 1162 times.
tdangelo
« on: 30 Oct 2013, 07:04 pm »
I have a pair of Carver 180 tube amps. Each amp has an attenuator which I don't use but it's the first thing the RCA input signal sees. I replaced them with the GoldPoint Mini V 100k attenuators and noticed a great improvement in transparency even with the GP wide open. I was wondering if I could just bypass the GP and wire direct?? I'm thinking the 100k resistance of the GP needs to be in the circuit?? If so maybe I could just insert some 100k resistors?? If so I'm not sure which wire to put the resistor on - there are 3 wires.
Any suggestions would be appreciated.
Tony
Speedskater
  • Kevin
Re: Attenuator wiring question
« Reply #1 on: 30 Oct 2013, 08:36 pm »
A resistor needs to be in the input circuit.
Are you running with the attenuators wide open?
tdangelo
« Reply #2 on: 30 Oct 2013, 08:38 pm »
Yes, wide open.
Thx
G Georgopoulos
« Reply #3 on: 30 Oct 2013, 11:31 pm »
Tony
You can take the pots out of the circuit and install in their place resistors
in-----------to tube grid
     | | resistor
     --- ground
with this arrangement only two wires are used
cheers  :green:
