0 Members and 1 Guest are viewing this topic. Read 7568 times.
So I'm wondering, rather than try and put something up on the ceiling (and/or floor), why can't the reflections be pre-emptively reflected somewhere else? Like this:
Depending on the reflector, there could potentially be issues with diffraction around the edges.
However, it's reasonably common to see the ceiling reflections directed towards the back of the room:
The wavelengths associated with the floor bounce effect might be a little large to reflect as you propose...
I have a drop ceiling in my listening room and, other than adding floor to ceiling bass traps in the corners, treating the ceiling had the biggest effect.
Try a line source array.
I also have a dropped ceiling and have not done any treatment yet. Would appreciate it if you'd explain what you did.Thanks very much.Rod
