Sensitivity: Cirrus Black vs. Joule Black
0 Members and 1 Guest are viewing this topic. Read 2726 times.
TF1216
« on: 28 Oct 2013, 09:27 pm »
Hey Guys,
Can you please help me understand how you achieve a higher sensitivity from your 3-way than your 2-way?  Is the 15H used in the Joule?
Also, can you please help me - and whoever else is interested - figure out how 35 watts from a tube amp will power each speaker?  One would think the tube amp would handle the 2-way, as a load, easier than the 3-way.  However, the higher sensitivity and the assumption that the bad a$$ AT woofer has a flat impedance curve has me confused what would be handled with less effort.
Any help here?  Thank you!!
Pete Schumacher
  • It's all in the pursuit
    • Vapor Audio
Re: Sensitivity: Cirrus Black vs. Joule Black
« Reply #1 on: 30 Oct 2013, 03:24 am »
Hey Guys,
Joule uses the Audiotechnology Flexunit 10" sandwich cone woofer.
It's all about the baseline sensitivity of the woofer.  Everything else has to fall in line.  Because the TD15H is a high sensitivity woofer, by definition it doesn't take much power to hit 90dB.  In this case, well under 1W will get you there.  The TD15H also has a relatively high impedance.  Over most of it's range, it's impedance is above 10 Ohm, so it's a super easy load for a tube amplifier.
A two-way like Cirrus has a woofer that is covering the full range from below 100Hz, where baffle step losses occur, up to 2000Hz where baffle step is completely gone.  That radiation space at 100Hz consumes approximately 6dB of the baseline sensitivity due to the woofer being away from the ground plane.  So in the case of Cirrus, there's more loss of sensitivity than with the Nimbus or Joule due to the woofer's proximity to the floor boundary.
So in this case, the huge Nimbus is actually an easier load for an amplifier than the smaller Cirrus due to the types of drivers employed.
Joule also has the same advantages as Nimbus since the woofer uses the floor boundary to keep some of its sensitivity.
By the way, on Sunday at RMAF, we were filling our 75' long room with Nimbus using the Arte Forma Aida, a 3.5W SET based on the 2A3 output tube.  There's certainly something special about a higher sensitivity speaker if you don't mind the larger footprint.
TF1216
« Reply #2 on: 30 Oct 2013, 03:44 am »
Thanks for the answer Pete.  I appreciate the time you took to write such a complete answer.
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
« Reply #3 on: 30 Oct 2013, 04:09 am »
And yes, we are still using the 15H SDKAM in the new Joule Black.  As Pete said, the vast majority of the time it's the driver handling bass duties that determines the final system sensitivity since it has to compensate for baffle step losses.  Since the woofers we use in the 3-way Joule and Nimbus start at higher sensitivity than the woofer in the Cirrus Black for instance, the final system sensitivity is higher.  However, in the Cirrus White, the Accuton C173 Neo is very high sensitivity (higher than the woofer in the Joule White), so the Cirrus White has higher system sensitivity.
The new Joule has a tapering transmission line, and another benefit of transmission lines is that the lower impedance bump is nearly eliminated ... that will help tube amps since the load is more 'even'.
TF1216
« Reply #4 on: 30 Oct 2013, 04:55 am »
Thank you Ryan. The 10C77 has been calling my name for a very long time.
