Need advice for battery for Dodd EL-84 amp
0 Members and 1 Guest are viewing this topic. Read 1865 times.
glynnw
  • I have tin ears.
« on: 24 Oct 2013, 04:03 pm »
I just purchased a used Dodd Audio EL-84 stereo amp, 15 watts,  and am unsure about what type of 12V battery to purchase to power it.  I have used a small 12V SLA battery to power a DAC, but this probably requires something a little heftier.  Any input is appreciated.
Atlplasma
  • Just off the boat
Re: Need advice for battery for Dodd EL-84 amp
« Reply #1 on: 24 Oct 2013, 04:11 pm »
I'm sure you'll get some good input here, but I suggest calling Gary Dodd. He will give you the best advice on using SLA 12 Volts to maximize the run time on your amp.
stretchphoto
« Reply #2 on: 30 Oct 2013, 05:13 pm »
Hi, Glynn.  I'm looking at the same amp.
Do you have any thoughts on the one you're now listening to?
Thanks.
 - Stretch
jparkhur
« Reply #3 on: 30 Oct 2013, 05:24 pm »
Power Sonic was what I was suggested and purchased..  100 AmpH battery.  I think it is the one Danny was using at RMAF.  You may not need one that big, depending on your usage.
Some starting points
http://www.batteryplex.com/powersonic.cfm
Get the good charger too.  7000 series.
I got this one.. http://www.batteryplex.com/powersonic.cfm/m/PS-121000
I only have a Dodd Pre and Dac on the battery.  I have left the charger off for two weeks at times depending on use.  Little draw from these devices, amps different of course..
HAL
« Reply #4 on: 30 Oct 2013, 05:37 pm »
The PowerSonic 100Ah battery was giving about 8-9 hours of playtime before it started to sag at RMAF with the Dodd Audio EL84 30 watt monoblocks.
Atlplasma
  • Just off the boat
« Reply #5 on: 30 Oct 2013, 05:51 pm »
Was the battery on a constant charge?
HAL
« Reply #6 on: 30 Oct 2013, 05:59 pm »
No.  Recharge at the end of the day.
TrungT
« Reply #7 on: 30 Oct 2013, 06:14 pm »
My 100Ah battery just plugged and forget about it.  :thumb:
Ctek 7002 charger.
jparkhur
« Reply #8 on: 30 Oct 2013, 06:25 pm »
Ctek 7002 charger.
I wanted to see if there was a difference, so I unplug it once in awhile.  JP
glynnw
  • I have tin ears.
« Reply #9 on: 1 Nov 2013, 08:17 pm »
Thanks for all the help.  I bought a 75aH SLA battery and a Ctek 7002 charger, after talking with Gary Dodd.  On this amp the battery charge lasts all day easily and I recharge at night.
