6H30 DR
0 Members and 1 Guest are viewing this topic. Read 3242 times.
bjski
6H30 DR
« on: 23 Oct 2013, 06:01 pm »
Hi,
Has anyone purchased 6H30 DR NOS lately? I have a hard time finding 6H30 DR. Have the prices increased so much that they become almost unaffordable? The cheapest prices I see are on EBay and it's $500 for a quad.
Any opinion's of the venders on EBay or am I just making them rich?
Re: 6H30 DR
« Reply #1 on: 26 Oct 2013, 09:38 am »
500 greenies :o Gulp!
I suggest you dismiss DR version and use the EB low priced at this reliable seller:
http://www.gstube.com/catalog/?key=6h30&submit=Find
By what I know they dont test the tubes its are factory tested only, but you may clear iut with Anton.
I never see a DR version avaliable, they are very similar to EB and dont worth the price(IMO):
ЕВ (EV) higher reliability, longer life and mechanical ruggedness.
ДР (DR) like EV, but especially specified reliability.
bjski
Re: 6H30 DR
« Reply #2 on: 28 Oct 2013, 07:03 pm »
thanks, i'll give them a try. do you have an opinion on what 6c19 to get. These tubes are for a Bat 32SE.
jparkhur
Re: 6H30 DR
« Reply #3 on: 28 Oct 2013, 07:50 pm »
http://www.upscaleaudio.com/russian-6h30-dr
189 cyroed last week
Yes, worth it...  Ebay... tough one..  concerns me when i can not drive to someone and beat them up for not sending product.....
jparkhur
Re: 6H30 DR
« Reply #4 on: 28 Oct 2013, 07:50 pm »
I have two right now, keeping them....  :)
Re: 6H30 DR
« Reply #5 on: 28 Oct 2013, 09:34 pm »
What 6c19 version??
Well there is these 6C19 versions avaliable at low price:
6C19n plain
6C19n-B
6C19n-BOC (out of stock)
6C19n-BP
http://www.gstube.com/catalog/?key=6c19&submit=Find
Considering it:
v (B) - military specification, usually indicates a higher heater current than the standard spec , which gives better S/N ratio. May also indicate different compliance, like anode impedance - check it out.
r (P) selected for low noise.
I would pick about 20/30 pieces from the BP version, as low noise is a very important feature for music amps.
