anyone ever heard of rpg?
0 Members and 1 Guest are viewing this topic. Read 2180 times.
vpolineni
« on: 1 Aug 2004, 06:41 pm »
I'm looking for some room treatments and came across this:
http://www.rpginc.com/products/studioinabox/index.htm
Has anyone ever heard of this company?  They seem to be well-known, especially the founder, Dr. Peter D’Antonio.  I currently have an eighth nerve room pack and 5 diy fiberglass boards using owens corning 703.  I'd appreciate any input.. thanks.
Tonto Yoder
« Reply #1 on: 1 Aug 2004, 06:58 pm »
I've not  actually HEARD their stuff, but they've been a staple of the Audio Advisor catalog for quite some time.
http://www.audioadvisor.com/store/mfglisting.asp?hdnMfg=RPG&MFGID=104
hifitommy
yes, they are widely used
« Reply #2 on: 1 Aug 2004, 07:36 pm »
in professional applications and they arent cheeeeep either.  brooks berdan in monrovia ca sells and uses them in his sound room.
http://www.rpginc.com/ is the site to explore.  i just ran a google search and it was on page 2.
Psychicanimal
« Reply #3 on: 12 Sep 2004, 07:54 pm »
I use their products.  Not cheap, but are based on research.  I think they're better than most of their competition.  It's definitely better than hanging pillows from the walls & room corners.
DSK
« Reply #4 on: 12 Sep 2004, 11:16 pm »
I used their B.A.D panels on the walls and Skylines on the ceiling of a previous listening room that needed treatment. They made more difference than I could have achieved from spending $5k or even $10k on equipment upgrades.
PhilNYC
« Reply #5 on: 12 Sep 2004, 11:18 pm »
I've had some experience with their Abffusors.  *very* effective products at sound absorption to the point where you have to worry about using too many and sucking too much life out of the sound.
hifitommy
one should never overdo any process
« Reply #6 on: 13 Sep 2004, 01:20 am »
room treatment, or whatever.  i am sure rpg offers guidance.
