0 Members and 1 Guest are viewing this topic. Read 18551 times.
It has to do with density of the material.
Interesting. I have been reading several threads that say R-13 is adequate and may even be better for bass traps. This is based off of the "superchunk" design, not rigid panels spanning the corners. I welcome further discussion about these 2 materials.
That's what I learned from you years ago. They were mentioning std OC pink as a better alternative to 703 in the super chunk form. This didn't make sense to me. I must not understand what super chunk is.
If you can find R-30 of the same material, that would be thicker, less cut pieces required. Now that you have me researching fluffy insulation for superchunks , it seems that if used, you don't want to stack it too high as is, due to the bottom pieces will compress from the weight above. So you have to come up with a way to support the layers every ? inches or so. Is this what you found? Here a gearslutz thread regarding this:http://www.gearslutz.com/board/bass-traps-acoustic-panels-foam-etc/750699-insulation-behind-straddled-corner-bass-traps.html
Doing fluffy behind 703 can help extend how low they will go. Doing full fluffy can have the effect of overabsorbing upper bass and lower mids with some materials.
...I too have been looking over the designs about how to stack either material in the corner and support it. I have a few ideas in my head, but nothing I am ready to commit to yet. Once I do figure out something, I plan to create a full blown build thread with pictures and descriptions of the process...
Superchunk is a bass trap that is triangular and fills the entire corner. Many make them by cutting acoustic material into the desired triangle size and stacking them to fill the corner.
http://www.audiocircle.com/index.php?action=gallery;area=manage;album=3817There is one photo in this old gallery of mine that shows how I framed the bass traps into the corner. Since they were floor to ceiling, I made a frame out of 1x3's with beveled edges and then wedged it between floor and ceiling. Maybe this will give you some more ideas. I stapled stretchy fabric that i covered my absorbers with over the frame first. The wedges just set on one another floor to ceiling.
Interesting idea. I would think that a staple would hold in a wall if it only had a couple layers of material on it. That may become a lengthy process though. I have been thinking more along the lines of framing it out into 3 sections and using peg board as the shelf.
