0 Members and 1 Guest are viewing this topic. Read 17062 times.
Yes, the biggest advantage to having a dedicated room is that you can listen to what, when, and how loud you want. IMO the biggest mistake most audiophiles make is to overspend on gear compared to the listening environment they're using. I don't know how to comment your post and/or insert my comments, therefore I will use the little smiley at the beginning of each sentence each time I will comment.My listening room is right above our bedroom and believe it or not I can ply music full blast and my wife don't hear a thing. That's the advantage of 10" of reinforced concrete.Plaster is harder (more reflective) than drywall (most popular wall construction in the U.S.). But the overall wall construction should be very rigid and so not contributing via resonance (flexure). My guest is that you're suffering from what Floyd Toole describes in his book "Sound Reproduction." His analogy used a bath tub filled with 10 cm of water and using a hand to push water from one end to the other (like your speakers are doing now as they're both at one end of the room). The waves slosh back and forth, from end to end. As they move back and forth the waves 'interfere' with each other, sometimes cancelling each other, sometimes doubling each other. Bass waves in your room can do the same (different places in the room at different frequencies). This cancelling/doubling can cause a +/- 20 dB response. I agree with you.The answer is not in treatments or EQ but to use a 'swarm' of subwoofers, spread around the room. (Search audiocircle or google for 'swarm'.) Minimum two subwoofers at opposite ends of the room, but three or four is recommended. Another option is found here: http://www.spatialcomputer.com/page9/page10/page10.html I have two Rythmik F12G sealed servo subwoofers that only wait to be connected to my amplifier.Nearfield is a loosely defined term. I use a 70 inch equilaterial triangle (speakers/listening position) as per Cardas (but some go much smaller, that could fit on a desktop) that images halfway between headphones/farfield. The soundstage 'snaps' into place, even 8 year olds are wow'd by the effect. 70" that's close, very close...Unless you're well trained in acoustics, don't kid yourself about what frequencies/dB you're hearing, do yourself a favor and do the testing. (Most audiophiles under estimate sound pressure levels and miss judge the frequencies they're hearing, especially bass.) I am looking at something that is simple and inexpensive to make some db/frequencies measurements.Zip code 48867 is Owosso, Michigan. Let me know where they'd be shipped to and I can look into the cost. Put those GIK 244 bass trap aside and don't let anyone touch them, now they are mine.I will get back to you as soon as possible.Hope you wont charge me stocking fees. Thanks again for everything.Guy 13
REW is not simple, nor I suspect is any other decent measuring software, because it's a complicated subject.
Guy:If your room is truly a 12'x12'x10' concrete echo echo echo box, I would suggest buying a good set of headphones.BUT your pictures suggest you are describing the listening area only, you must also include your office area into the equation. Acoustically a curtain divider does not define the room, it is the area between the "hard" walls that is important.Now in your real room you have four potential bass trap corners available again, the front corners are ideally suited for typical 45 degree floor to ceiling corner bass traps, the back corners are somewhat complicated by the door and the office window.The pictures do not show the office window area clearly but the shallow alcove behind the door would also be a perfect candidate for a 6" deep flat floor to ceiling trap.Then start on the 1st reflection side wall absorbers, curtains are a start but they have to be pretty thick, maybe backup your current setup with cheap felt/cotton shipping blankets.We really need to see a more accurate floorplan of your actual listening "room" to make detailed suggestions.As for the textiles required check into local industrial sources for fiberglass insulation, felt blankets ?? they may be cheaper than the local shops.I envy you, my fingers are starting to go numb, as I type this response in my smoking area / garage, it's getting colder 4C.Shawn
REW is a measuring software that is free. You need a computer, microphone (Behringer ECM8000 is relatively cheap and effective - in Europe anyway), microphone stand and cable. Some use a sound pressure level meter instead of a microphone.However, REW is not simple, nor I suspect is any other decent measuring software, because it's a complicated subject.The simplest way would be to buy a test CD with test tones (Stereophile's first one is good) and a sound pressure level meter like the ubiquitous Radio Shack one.Both these approaches will help you position your speakers and ears for least problematic sound and will identify the areas you can improve with room treatment. If you use an equaliser as I do it can show you what settings you need.I've been a wannabee audiophile for around nine years but it's taken me to this year to get things approaching right. I'd dabbled with test tones and SPL meters but this year I decided to do the job properly and use REW. It's tough to learn as there are so many things to go wrong and so many options, but there's good advice on their forum. I wouldn't say it was 100% accurate (I can't believe any software/microphone combination is) but it will get you near your target. The final test is always your ears.If you plan on listening seriously for a number of years, changing rooms, houses and equipment, I recommend learning a software like REW now as it will help you well in the future.
Agreed, using REW is more complicated than playing test tones with an SPL meter, but it's not terribly difficult. Especially now that there are affordable USB microphones suitable for the job. This should help:Room Measuring PrimerHi-fi is a hobby, and like any hobby the more we put into understanding it the more enjoyable it will be.--Ethan
Agreed, I tried Stereophile test tones and Radio Shack spl meter (with the corrections). Then I finally learned how to do the use my Behringer DEQ2496 (another steep learning curve) with ECM-8000 microphone - and got much better results. 99% of audiophiles (including me) simply don't have an ear trained to do this properly.Guy, do give nearfield a try, it's free so what do you have to lose? And read up on the swam theory and give it a try too (you might not even need my GIK panels).
I sure don't want to sound rude, but I am not interested in complicated stuff
That's not rude, just honest. Maybe you have a local friend who's knowledgeable and is willing to help you?--Ethan
One of these days I'll post the "morph" photo I made of me transforming into my kitty Noah.
