How do you store your tubes and keep your notes on your tube collection?
0 Members and 1 Guest are viewing this topic. Read 1452 times.
Big Red Machine
Sometimes we buy matched pairs and sometimes quads or singles, depending on the application.  For me, I like to keep my original receipt so I know what the heck I have and where I got it, and some kind of notation on how I heard it perform.  This makes the storage a little wonky as you have tubes you are trying to protect and store and paperwork that does not fit the same form factor.
Now I only have about 30 tubes and tend not to sell them once I have coveted them but I want to know how you experts keep and organize the tubes and their performance notes.  I personally hate cardboard boxes since they are so hard to open.  I'm thinking plastic tubes or.....
JoshK
I'll share what I think would be a good system, that unfortunately I never used myself, so I am semi-disorganized.
I think the ideal system would be to create a simple database (use Access or whatever other free db out there).  In the DB, you can fill in fields for all the details, like type, brand, purchase price, from whom you bought, test readings, whatever else.   I think you should also have a field where you have some code that identifies pairs/quads.   All of these would be easily searchable because DB's let you sort and search by fields.    But here is the cool thing; databases are designed around a key that identifies unique entries.   Write this key on the tube box, so that you can look up the key for a tube and bring up all the details you entered.
For storage, I have a large craftman's tool case and surprisingly the sizes of the different drawers fit the different size tubes I have quite well (I have hundreds).   I have them organized by type and where possibly many of the details are written on the boxes, but the price paid and other notes would have been nice to have kept track of.   :duh:  Also, for me it would have been nice to know what design usage inspired the purchase as I don't typically buy the usual suspects (12A*7, 6DJ8, etc).
You can very quickly build a form in access or similar that you use to input all the fields, which makes it simpler.    Or if you don't want to bother with a DB (although there is advantages to doing so) you could always just use a spreadsheet, although I highly recommend creating a "key" for each tube to be written on the box.
TomS
I use a small Dymo label on all of the plastic and metal base tubes, numbering them 1 through n, with a second label on their boxes. Then I create an entry in a spreadsheet with all of the details about when I bought them, who, listening thoughts, etc. I keep the purchase info in a paper file and reference those same Dymo label numbers. The 9-pin tubes get a label on the box itself with a small picture of the actual tube taped next to it so I don't mix them up. All of the tubes go in a Sterilite clear plastic box with lids. Inside are Christmas ornament type cardboard dividers. The tubes in boxes fit in there in the same order as the Dymo labels. Easy to find that way.
« Last Edit: 16 Oct 2013, 08:47 pm by TomS »
JakeJ
You guys are more organized than I.  Most of my small signal tubes are in a tube caddy and there are a small amount of output and rectifier tubes in the bottom.  the rest are in boxes with bubble wrap protecting them.  Unfortunately many of my tubes do not have tube boxes.  The database is a good idea and something I have wanted to do but haven't gotten a round to it.
Maybe now I will.  :lol:
totally agree with Josh.  A DB is  going to be the most versitile but you can   put the entries into any form you like ... DB, spread sheet,  even a  simple document  if you like.  The  main thing is to make sure you have that  identifiying "key"  on both the entry and also on the  particular tube/box  (you can put the key on both if you like by using  those little stickers. )
 I probably  don't have to say this but  ...  be sure to create a backup  and  keep it up to date
-jay
rbwalt
i store my tubes in one of those plastic bags which you can suck all the air out. vacuum tubes stored in a vacuum. i just put a note in with them referencing whether the tube is good or bad and where it came from( socket ). this make perfect sense to me to do this as it protects the tubes in air free environment so the pins do not oxidize. then i put them in a nice box with lots of peanuts and label the box audio tubes so as not to get them mixed up with my other stuff.
Bob2
I have like 4......umm, ok!
I have to catalog these...anyone still using the Dewey decimal system?
Seriously though when I retire I intend to acquire more then, look to this thread for advice on how to store and record where, when and why I have so many.
That is if adrianc leaves any for the rest of us. He must have the best collection in the whole world...I bow to you adrianc. Awesome!
Big Red Machine
You guys are pretty organized.  I have 3 small plastic containers with a mishmash so I need to clean that up.  While I won't go to DB level, I think Excel is adequate.  What I have done quite a bit is print out the info/receipt for the tubes and wrap them around the tubes with a rubber band so I have them all in one place.  I am not a tube expert so I need cheater notes to keep my square getters from my D getters from my T plates!
