0 Members and 1 Guest are viewing this topic. Read 8155 times.
From the Omega website, the deepOmega Micron subwoofer has high level (speaker cable) inputs, low level (RCA) stereo inputs, and combined low level (RCA) input (otherwise known as LFE or Low Frequency Effects). So lots of options to pick from.If your integrated has LFE output, you can use it. The output will send only low frequency signal to the sub (most cut off at around 80 Hz).If your integrated has pre-amplifier outputs, you can use them. The output would include all frequencies. The sub has a frequency cutoff adjustment from 40 - 200 Hz which should provide plenty of control. The subwoofer's RCA outputs could then be routed back to the integrated's power amp inputs to feed the main speakers.If your integrated has neither of the above, you can connect the sub using the speaker outputs. Again the output would include all frequencies and the frequency cutoff can be adjusted. You'd then need to connect the main speakers through the subwoofer outputs. Note that the subwoofer would still use it's own power amp and not take power from the integrated.Purists would use the pre-amp outputs to keep the signal as clean as possible, but which method works best is up to you.
I've been using a single 10" sealed sub, it works fine, just play with placement until you get the best results you can. I would start with the sub between the speakers. I would like to upgrade to multiple 12s but a single 10 is better than nothing...
