dc brush motor for turntable
0 Members and 1 Guest are viewing this topic. Read 981 times.
G Georgopoulos
« on: 11 Oct 2013, 01:06 am »
I plan to use dc brush motor for a turntable turn system
,has enyone used this type of motor before ?
,is it noisy ?...etc...
cheers  :green:
neobop
  • BIRD LIVES
Re: dc brush motor for turntable
« Reply #1 on: 11 Oct 2013, 02:44 am »
I think brushless is preferred because the brushes wear out.  DC motors are often used and the speed is controlled by varying the voltage.
You might want to take a look at this DIY thread:
http://www.diyaudio.com/forums/analogue-source/176077-official-turntable-drive-system-motor-thread.html
neo
