Audio/Video Gear and Systems
Owner's Circles
Salk Signature Sound Owner's Circle
jsalk
Socket size needed to remove the plinth bolts on STs?
0 Members and 1 Guest are viewing this topic. Read 1302 times.
billmcc
10 Oct 2013, 01:02 pm »
I'm helping a friend break down and ship their Veracity STs this morning. I can't recall the socket size I used to apply the lag bolts on the plinths of my STs. Anyone recall what size socket is needed? I have my STs positioned just right and would prefer not to move them to check. Thanks
Bill
Big Red Machine
Re: Socket size needed to remove the plinth bolts on STs?
10 Oct 2013, 01:17 pm »
I think it is 1/2 inch. I believe all the plinths use the same screws. If not 1/2 then 9/16.
J Fallows
melomane
Reply #2 on:
10 Oct 2013, 02:40 pm »
The lag bolts are 5/16 x 2 1/2". It takes a 1/2" socket to unscrew them. 13mm works too.
billmcc
Reply #3 on:
10 Oct 2013, 09:36 pm »
BRM and J Fallows,
Thank you very much for your help
. They are in fact 1/2" and everything worked out fine!
Bill
Owner's Circles
jsalk
