Looking to upgrade USB/SPDIF converter
0 Members and 1 Guest are viewing this topic. Read 2335 times.
mesch
« on: 9 Oct 2013, 01:45 pm »
 First post on Audiocircle, hope this lands in the right place. I am looking to upgrade from a M2Tech hiface to another converter. I use Pure Music on Mac Mini to Hiface to Bryston BDA-1 DAC.  I have redbook CDs as AIFF files.   The offramp 5 would be my choice but out of budget.  Looking for recommendations, thoughts. Thanks in advance.
audioengr
Re: Looking to upgrade USB/SPDIF converter
« Reply #1 on: 9 Oct 2013, 07:16 pm »
A few distinctions with the Off-Ramp 5:
1) independent custom Hynes regulators on each circuit delivers lowest jitter
2) separate power supply from the USB cable power
3) true 75 ohm S/PDIF output
4) Silver-plated multi-layer circuit boards for lowest crosstalk and skin effect
5) low-jitter Turboclock custom clock
With the new Dynamo power supply, it is unchallenged in the marketplace IMO
Even the stock OR5 with the S/PDIF Hynes upgrade is wonderful.
Steve N.
