DAC suggestions
0 Members and 1 Guest are viewing this topic. Read 3363 times.
jetpack
DAC suggestions
« on: 9 Oct 2013, 07:01 am »
Hi experts.
I'm looking for a new DAC and will be travelling to Tokyo soon. I'm hoping for some recommendations in the 200-1000 USD range that I can pick up in the Akihabara or elsewhere. I need something for converting digital signals from my cd player and a macbook +/- an adroid phone and ipod. Maybe I'll add a wifi streamer too at some point. Post-DAC, my system is a Clarinet tube pre followed by a SET 2A3 and a gainclone amps running frugalhorns and a couple of small woofers.
Any advice is greatly appreciated!
wisnon
Re: DAC suggestions
« Reply #1 on: 9 Oct 2013, 01:15 pm »
Teac UD-500
Geek dac
iFi IDSD
Ressonessence Concero HD.
TF1216
Re: DAC suggestions
« Reply #2 on: 9 Oct 2013, 01:57 pm »
Here are nice words about the Concero HD (http://parttimeaudiophile.com/2013/10/05/resonessence-labs-concero-hd/#more-7182).
Resonessence Labs is debuting the Herus at RMAF.  It's mainly for headphone use but it does appear to have decent specs for a home audio setup.
jaywills
Re: DAC suggestions
« Reply #3 on: 9 Oct 2013, 06:25 pm »
I've has a Ressonessence Concero HD for a couple of months now and like it quite a bit.  Preferred it over the Peachtree Dac*It (which is a nice sounding DAC, BTW) and the internal DAC in my TacT 2.2x.  Of course, YMMV.  Good luck. Cordially,
jetpack
Re: DAC suggestions
« Reply #4 on: 9 Oct 2013, 08:05 pm »
Thanks a lot for the suggestions. I'll try to hunt up a place to listen to the Teac and Concero. Import duties are too extreme where I live to mail-order anything and the mark-up of local hifi shops tends to push prices out of my budget. I'll do a bit more internet investigation into the iFi too. Cheers.
Atlplasma
  • Just off the boat
Re: DAC suggestions
« Reply #5 on: 9 Oct 2013, 08:15 pm »
Teac UD-500
Geek dac
iFi IDSD
It's the Teac UD-501 (not 500) unless they are using a different model designation in Japan.
charmerci
Re: DAC suggestions
« Reply #6 on: 10 Oct 2013, 01:41 am »
« Last Edit: 10 Oct 2013, 03:08 am by charmerci »
charmerci
Re: DAC suggestions
« Reply #7 on: 10 Oct 2013, 03:07 am »
Could pick up an inexpensive JDLabs ODAC (under $170) as an additional spare/convenient DAC to have in addition to whatever you get before you leave the U.S. It's very small and you just plug it into your computer - no worries about foreign electrical voltage differences.
dunross
Re: DAC suggestions
« Reply #8 on: 12 Oct 2013, 03:39 am »
Take a look at Audio-GD's DAC offerings. They are in China and ship to Japan all the time. If you see something that interests you, contact them explaining your situation. They must know quite a bit about shipping to Japan and may offer a workable solution. I think their dac's are great too.
doctorcilantro
Re: DAC suggestions
« Reply #9 on: 13 Oct 2013, 06:13 pm »
If you can stretch the Yulong DA8 and BMD PUREDAC.
jetpack
Re: DAC suggestions
« Reply #10 on: 14 Oct 2013, 09:32 pm »
Thanks for the further thoughts. I'm particularly intrigued by the Yulong DA8 and TEAC. Looking into it a bit more, I'm curious about the differences between DSD and PCM. I have very little knowledge about the conversion to analogue, but a fair background in time series and DSP. It would be fun to compare them back to back. I guess the real danger is that I keep inching up my price limit until it is absurdly incongrous with my income and DIY-based system!
J_P_425
Re: DAC suggestions
« Reply #11 on: 17 Oct 2013, 09:49 pm »
If you are using purely PCM and single ended interconnects the John Kenny Ciunas is a notable DAC to consider. It definitely does a better job with PCM than the TEAC. On the other hand, if you want to get into a DSD DAC the TEAC UD-501 offers tons of options at a very modest price point.
