SA-1 GR Research (Now discountinued) plate amplifiers.
0 Members and 1 Guest are viewing this topic. Read 1290 times.
Guy 13
Hi Danny and all Audio Circle members.
If you remember, I bought from you four (04) GR Research SA-1 (Now discontinued) plate amplifiers and eight (08) 12” woofers (Eminence Acoustinator).
Can I connect two amplifiers in parallel with the high level input connectors and have two 8 Ohms speakers in parallel for each amplifier.
That would make two woofers per amplifier for a total of two amplifiers and four woofers for each side/channel.
The four woofers would be in H frame configuration and the coaxial drive would be in a separate OB enclosure at ears level.
What do you think, will it work?
Guy 13
The crazy ideas guy…
Danny Richie
Re: SA-1 GR Research (Now discountinued) plate amplifiers.
« Reply #1 on: 8 Oct 2013, 02:00 pm »
Yep, that works.
