N3 - TL or BR ?
0 Members and 1 Guest are viewing this topic. Read 1499 times.
Guy 13
N3 - TL or BR ?
« on: 5 Oct 2013, 12:33 pm »
Hi Danny and all Audio Circle members.
You might remember that I bought from you a pair of N3.
If I want to up-grade the enclosure from the N3 to N3TL,
unless I am wrong, the improvement will be mainly in the bass region,
am I right?
Now, how about the difference in sound (Mainly bass) between the
N3 in a TL enclosure versus bass reflex enclosure ? ? ?
Of course a bass reflex enclosure is a lot easier to build,
especially for someone like me with five thumbs instead of 4 fingers
and one thumb.  :lol:
Guy 13
Danny Richie
Re: N3 - TL or BR ?
« Reply #1 on: 5 Oct 2013, 02:54 pm »
The improvement from the TL cabinet is lower bass extension, more low bass output, better driver control, and slightly more effortless lower mid-range.
A bass reflex design will allow a -3db down point of 48Hz with these woofers.
The TL design allows a -3db of 40.5Hz.
And the TL design is actually just as easy to build as a bass reflex design. And there are plans for it. There are no plans available for a bass reflex design.
Guy 13
Re: N3 - TL or BR ?
« Reply #2 on: 6 Oct 2013, 01:54 am »
Thanks for the info.
Since I will give some help to the N3 in the bass region
with my two F12G Rythmik subwoofer,
the Bass Reflex would me the way to go,
if I build the enclosures myself.
If the enclosures are built by my cabinet maker,
then I will go only with the TL just in case someone wants
to buy my subwoofers and I want to use the money to upgrade
something in my system.
Thanks again.
Guy 13
Danny Richie
Re: N3 - TL or BR ?
« Reply #3 on: 6 Oct 2013, 01:59 am »
It will actually sound better with the TL cabinet and blend better with the sub. Been there done that, and to me it didn't make sense to offer it with a ported box. The TL design just sounded too much better.
And if you build a ported box then you have to build a stand for it. The TL design doesn't need a stand.
