Replacing the batteries in the 5A crossover and high pass filters
0 Members and 1 Guest are viewing this topic. Read 2900 times.
zybar
Has anybody successfully done this?
How difficult or easy is it?
Any tips or gotchas I should know about?
George
jeffreybehr
I've had my 5A crossovers out and have modified them slightly.  (Only a Philips screwdriver is necessary to remove them from the speakers.)  As you can see, they are complicated and quite crowded.  Here's a pic of an original.
The batteries are soldered and strapped onto the board, so replacing them requires some soldering and mechanical skills.  I strongly suggest you remove the crossovers and measure the total voltage; the batteries are wired in series, so 'good' would be somewhere in the mid to high 20s.
