0 Members and 1 Guest are viewing this topic. Read 7710 times.
What are the dimensions of your listening room?
My room is 4.5 m wide x 3m ,
Hi,It is the ST Supercharged similiar to song towers but quite a bit more expensive. It has a similiar footprint to the song tower series speakers but uses 2 x seas mid bass drivers plus the raal ribbon tweeter. I understand that you have a small room but these might be just right for you and I'm confident that they would sound great. I had the HT2 speakers and they are wonderful. When you factor in shipping and the extra costs of importing I just think its worth doing it once and getting some really top notch speakers (not that the song towers aren't good either). Just my opinion though.Cheers Rod
The actual name of the speaker is the Veracity ST. The mid/bass drivers are Seas from the same series as the other Veracity speakers.
Actually, the Veracity ST uses a larger driver than the SCST. I just checked the Salk website and noticed the SCST is no longer listed. Perhaps they were so similar they decided to drop the SCST from the website?Of course being a custom builder one could have Jim build either one.
Hi,Whilst the room is small I would still consider the Salk Sound HT2TL's. My new speakers should be shipping by Air from the US to Perth, W.A. in a few days time. This is the second pair of speakers that I've had shipped to Australia.Good luck with your decision.Regards Rod
