0 Members and 1 Guest are viewing this topic. Read 4028 times.
This is if you intend to use it on the AC side, otherwise it's different. I say this because I can't figure out why you'd try to put it between on the DC, as the capacitors in a Felix won't do anything on the DC side. They'll just charge and stay charged, so it isn't even possible for them to filter. Your diagram is only showing capacitors to prevent voltage drop. SO assuming you want to re-think the design and put the Felix AC side...
From what I gather your adapter probably uses around tops, 1A. That'd be 50% efficient. Given that it's probably a switcher, it'd be more efficient. Let me know if that isn't the case. But for example it's 5A 12VDC, or 60W. 60W/120V = .5A usage at 100% efficient (which it isn't) .
So with no shortage of concern, a 3A rated CMC would be fine, but I'd recommend a CMC/DMC. It does more filtration because it not only does common mode, but also differential. The P3717-AL would be a great choice. Overall it will reduce more noise.
