SOLD FS: Von Schweikert VR-35 Export Deluxe Loadspeakers - PRICE REDUCED
0 Members and 1 Guest are viewing this topic. Read 3149 times.
achappy
SOLD
Buyer pays for shipping: 52”x20”x16” box, 140 lbs for each box times 2. Seller's zip code is 33701.
Price is $4300.00
New Retail $8000.00
Mint condition Von Schweikert VR-35 Export Deluxe Loudspeakers.  If using PayPal add 3% to the purchase price.
Thanks for looking.
Reviews:
http://enjoythemusic.com/superioraudio/equipment/0711/von_schweikert_vr_35_export_deluxe.htm
http://www.ultraaudio.com/index.php?option=com_content&view=article&id=271:von-schweikert-audio-vr-35-export-deluxe-loudspeakers&catid=37:full-length-reviews&Itemid=2
Specifications:
Frequency Response: 25 Hz to 30 kHz (+/- 3dB)
Sensitivity: 90dB/W/m
Impedance: 8 Ohms nominal, with a minimum of 5 Ohms @ 25 Hz.
Tweeter: 1" treated fabric dome, Danish-designed Dual Ring design with rear chamber for low resonance and powerful response down to the midrange band, Low Distortion Motor, and custom voice coil/top plate design for low distortion.
Midrange: Two Scan-Design 6" treated paper cast-frame bass-mids with low distortion motors, elevated spiders, copper clad pole pieces, and composite laminated cones using cellulose acetate pulp, plastic resin, and carbon impregnation to eliminate standing waves on the cone surface.
Crossover: First order circuit using "audiophile-grade" parts, with cross points set  at 80 Hz and 6 kHz. All crossover parts are made by Mundorf and Erse, with custom solid copper foil capacitors insulated with Teflon dielectric film.
Subwoofer: Scan-Design custom 10" with Low Distortion Motor, laminated composite cone, elevated spider, long throw design, and copper clad pole piece.
Woofer Alignment: Quasi-transmission line design using three chambers, each tuned to a different resonant frequency to extend the bandwidth and reduce "one note bass" typical of ported boxes. Woofer "fires" at rear wall to boost the bass at 20 Hz by 3dB, and can be "tuned" by user.
Power Rating: 35 watts minimum, up to 500 watts on peak music.
Dimensions: 50 x 16 x 12 (HxWxD in inches)
Weight: 112 lbs. each
« Last Edit: 7 Oct 2013, 12:34 am by achappy »
achappy
Re: FS: Von Schweikert VR-35 Export Deluxe Loadspeakers
« Reply #1 on: 28 Sep 2013, 06:24 pm »
BUMP
achappy
« Reply #2 on: 4 Oct 2013, 11:05 am »
BUMP
