TBI MAGELLAN VIIIsu SUBWOOFERS & DUAL-MONO SUB AMP DEMO SPECIAL
0 Members and 1 Guest are viewing this topic. Read 3366 times.
William Crane
    • http://cranehometheater.com/
PRICE DROP!
World's Quickest Subwoofers
And the most musical. Invisable integration with mains. No boom. [/center]
"The TBI subwoofers are the only subwoofers I would use in a music system. They may not satisfy the listener who wants the room to shake and bass to sound like a rock concert bass. But if you like bass that sounds natural and blends with about any speaker system, the TBI might be for you." - Clay Swartz, Audiophile Audition http://audaud.com/2010/05/tbi-magellan-mgd-200-subwoofer-amplifier-srp-700/
"What I heard was as much pitch definition, individual note definition, beat definition, leading edge definition, and trailing edge definition as I had ever heard from a speaker reproducing bass, let alone from a subwoofer. The Magellans didn't just keep up with the speed of the Quads: for all intents and purposes, they had become part of the Quads."
STEREOTIMES.COM review http://stereotimes.com/speak112204.shtml
"The TBI Magellan VII xu Subwoofer used with the MGD-200 Subwoofer amplifier is without a doubt the finest subwoofer system I have ever had in my house, or for that matter that I have ever heard anywhere else. They are so easy to place and blend, and are such an easy size to work with. This combination means they should surely be on your short list if you are looking for a subwoofer."
Jack Roberts DAGOGO review http://www.dagogo.com/View-Article.asp?hArticle=876
AUDIOCIRCLE: Circles »Audio/Video Gear and Systems »Enclosures » Topic: TBI Magellan viii su subwoofer with TU 200 amp
http://www.audiocircle.com/index.php?topic=111723.0
These are the fastest subs available anywhere and they are the best at blending seamlessly with your main loudspeakers. When properly set-up, you won't be able to tell the location t he subwoofer. So you won't hear a boom off to the side(of course TBIs don't boom) as with most subs, but a smooth integration and bass extension added to your speakers. We are an authorized TBI dealer and can supply you with all models.
The MAGELLAN VIII su is truly a work horse in deep bass performance. Naturally a larger driver is going to have some increase in mass but the MAGELLAN VIII su compensates by requiring even less diaphragm travel to produce the same level. The truly remarkable property of REATL™ designs is the absolutely constant loading of the driver cone at all frequencies to allow our MAGELLAN VIII su to perform to 10Hz at full power input. Performance into the infrasonic range is exemplary when you consider that it is realized with a low mass driver capable of disappearing in an audiophile system even at high crossover frequencies. While only 3" wider than its smaller siblings it is a remarkably smooth performer with higher power handling and deeper response all while out performing any other subwoofer design.
Patented technology that uniquely combines transmission line and port designs to develop astonishing bass that is fast, accurate and blends with your main loudspeakers.
MAGELLAN VIIIsu SPECIFICATIONS:
FREQUENCY RESPONSE 12 Hz – 160 Hz (–6db)
POWER CAPACITY 120 W RMS (200 W IHF)
SENSITIVITY 90 db 1w/1m @ 25Hz
DRIVER COMPLEMENT 8" Low Mass Single Piece Convex Aluminum Cone
CONNECTION 5-way binding post
IMPEDANCE 8 ohms nominal
ACCESSORIES Custom Brass Isolators - Standard Large Rubber Feet
DIMENSIONS:
WIDTH 17.5 inches (444.5 mm)
DEPTH 17.5 inches (444.5 mm)
HEIGHT 6.8 inches ( 172.72 mm) no feet - [8.5" ( 215.9 mm) w/spikes ]
WEIGHT 26 lbs (12kg)
TBI MAGELLAN MGD-200 Class D subwoofer amplifer and crossover
The Magellan MGD-200 subwoofer amplifier represents the state of the art in its class for bass musicality and is the beast sub amp TBI has ever offered. It was never available on the TBI website, just through selected dealers. The MGD-200 was developed to power the new class of passive subwoofers utilizing the Embedded Transmission Line (ETL™) to establish true low frequency extension without mass or resonance. As a result the focus for the MGD-200 was to provide low distortion with ample power and control of a non-resonant piston system while providing required integration facilities.
Utilizing high quality parts throughout the MGD-200 provides 200 watts to 4-ohm speaker loads but more amply using cutting edge class D technology to accomplish its power transfer. The extremely low impedance of the amplifier over the low frequency range provides near perfect signal transfer to the non-resonate load. Stable and low impedance assures linearity of the signal transfer to the load through proper cabling.
FRONT PANEL: The attractive front panel is designed to complement your high-end components with it complete control layout. The MGD-200 provides control of the low-frequency crossover while providing a fixed 70 Hz high pass for bass shy satellites. The crossover control has a wide range of adjustment from 30 Hz to 200 Hz allowing bass rich or bass shy satellites to accomplish extension when the Magellan passive subs are utilized. The low pass crossover slope for the MGD-200 is 12db/oct.
To assist the crossover control the MGD-200 includes a volume with a 52db gain range, a phase switch and a subsonic filter especially helpful for turntable owners. This useful addition provides near flat response to 25 Hz with a deep attenuation at 10 Hz to avoid rumble or low frequency noise in some CD recordings. The MGD-200 features an exceptionally broad crossover range adjustment allowing for integration with many types of satellites.
There is a power on-off button with a auto switch allowing for continuous operation or for the amplifier to enter into a standby mode. This action is indicated by the dual color LED with red for standby and green for active operation. Power is maintained to all linear circuitry during standby mode.
REAR PANEL: The amplifier connects to an audio preamplifier or surround line level output using gold plated RCA jacks conveniently located on the rear panel. Additional adjacent jacks allow for you to continue feeding this signal to other line level processing equipment eliminating the need for Y-type signal splitters in some cases.
The rear panel also includes speaker level inputs and outputs to allow for insertion into any type of audiophile music system. There are 5-way binding posts that allow for you to connect your amplifiers speaker outputs directly to the MGD-20 speaker inputs. This transfers the signal into the high level sampling inputs of the MGD-200.This purely resistive 200Ω input does not load your amplifier and will be a parallel connection with your main speakers if they remain connected directly to your amplifier.
This method of connection will allow use of the high quality passive high pass filter incorporated in the speaker out terminals. This filter is a very simple 6db/oct filter employing a film bypassed high-end bipolar roll-off capacitor. When your main speakers are connected to these terminals there will be a gentle reduction of low frequencies beginning at 70Hz. This benign filter relieves bass shy satellites of congestion caused by feeding them bass frequencies that they don’t handle well while maintaining a pristine phase characteristic. The filter characteristic is based on an 8 ohm load.
The Magellan MGD-200 allows for the connection of two passive Magellan bass extension modules. These outputs are marked Subwoofer Output A and B. The total combined impedance should be maintained at or above 4 ohms for best performance if other types of passive subs are used. The output is 150 W into a single 8Ω load and 200 W total into two 8Ω loads
The MGD-200 operates on 120v or 240v when used with the proper adapter. This selection is not automatic however and care must be taken to assure that the proper voltage is selected prior to connecting to an AC supply. The red voltage selector switch is conveniently located next to the AC input. An adapter for the local supply will be necessary when using the supplied IEC cord. The main fuse is located in the power receptacle housing as marked.
Specifications:
AMPLIFIER TYPE
Dual Mono Subwoofer Amplifier
POWER SUPPLY
High Capacity Toroidal Transformer with Split Supply
TECHNOLOGY
Class D Half Bridge PWM
FREQUENCY RESPONSE
10 Hz to 200 Hz -3db /-6db (filter limited)
Subsonic Engaged (10Hz = -10 db)
POWER OUTPUT
150W RMS @ 8Ω / 200W RMS @ 4Ω
CONTROLS
Level-Phase-Crossover-Subsonic Filter
Auto Standby Defeat
CROSSOVER RANGE
30Hz – 200Hz (12db/oct)
CONNECTIONS
4-way Binding Posts / RCA Line Inputs
INPUTS
Speaker Level In / Line Level In
OUTPUTS
Passive Filter Speaker Out (70Hz@6db/oct)
Subwoofer Out A / B
RCA Line Level Pass Through
ACCESSORIES
IEC Power Cord, Owners Manual
DIMENSIONS
17” W x 13” D x 2.5” H (431.8mm x 330.2mm x 63.5mm)
WEIGHT
13lbs (5.9kg)
POWER REQUIREMENT
120V- 240V 50-60-Hz (250W @ max power)
Voltage Externally Selectable
Demo pair TBI MAGELLAN VIIIsu and one one TBI MGD-200 Subwoofer Amplifier. Plus shipping. Ships in three boxes.
MSRP: $3,200
SELL: $1995
CRANEHOMETHEATER.COM
« Last Edit: 29 Sep 2013, 08:53 pm by William Crane »
Goosepond
  • Virna!
PM sent.
Gene
