FS: PS Audio NuWave DAC (Excellent)
0 Members and 1 Guest are viewing this topic. Read 1504 times.
matevana
« on: 19 Sep 2013, 09:04 pm »
Up for sale is a barely used PS Audio NuWave DAC. It is an excellent sounding DAC and built like a tank. If I didn't need the money, I would not be selling it. It is currently registered with PS Audio and under full warranty. Comes with manual, IEC power cord and USB driver disk. Will be shipped FedEx Home Delivery, Signature Required, insured for the full purchase price. PayPal OK.
I will consider all reasonable offers. The current retail is $995 so please be realistic.
For fastest response, please email me at: [email protected]
Here's some highlights from PS-Audio:
The NWD features the latest fully balanced generation of 192kHz 24-Bit resolution Burr Brown engines with 123dB dynamic performance and rated THD a stunningly low 0.0005%.
It comes with differential outputs, an 8 times oversampling filter, Native mode, XMOS asynchronous USB processor, new low jitter clocks providing exceptionally lifelike audio.
Our engineers based the NWD around a solid high-performance DAC engine, state-of-the art XMOS processor and then designed an all new input circuit based on the PerfectWave low jitter clocks, a 100% discrete output stage and a huge power supply to finish it off.
This is true high-end.  You won’t find any chip op amps in this product.
192kHz 24 asynchronous USB
The NWD features our new high-resolution USB path based on the same XMOS technology found in our PerfectWave DAC.
Asynchronous and capable of 24 bit 192kHz performance, the NWD USB input sounds every bit as good as the best digital audio is capable of.
Using a high quality USB cable between the NWD and your computer you create an instant media server that can be controlled through any number of hand held devices like an iPod, iPhone or Android using a 3d party controller program.
Active vs. passive filtering: Once the digital audio data have been processed through the NWD’s input stage it’s time to turn them into music and this is the job of the analog filter and the output stage.
Most DACS use an active filtering system to clean up the output of the internal DAC but this can add a harsh bright sound to the music.
In the NWD we use all passive analog filtering and discrete current to voltage conversion giving our output a sweet open sound unencumbered with harsh digital artifacts.
Balanced outputs: The NWD is a class A fully balanced design that uses an output stage configuration similar to that of a power amplifier.
This is important to the sound quality of the DAC because driving even medium lengths of analog interconnect cables can be a sonic challenge if this critical stage is not designed properly.
Offered on the read of the NWD is both balanced XLR and single ended RCA cables, driven from this high current low impedance output stage.
FET discrete output stage: The real challenge to keeping the music open and analog-like is staying away from chip op-amps and current to voltage converters.
Chip op-amps are used by the vast majority of all high-end DACS and while good, they just don’t have the openness and sweetness of an all discrete, high voltage class A circuit.
The NWD features a 100% class A discrete, high voltage, FET based output stage.
Here we use luscious, analog sounding FET’s at the input and low noise powerful bipolar transistors for the gain and high current low impedance output stage.
Everything is direct DC coupled so bass is  stunning in its power and impact as well as the all important midbass region where the human ear is sensitive to any alteration in sound quality.
The all important power supply: If you want high-end performance you need a high-end power supply.
Inside the NWD is a huge transformer, coupled to many thousands of microfarads of capacitance, Linear Technologies regulators and high speed, low noise diodes.  We have taken every effort to make the NWD as good as it gets through careful power supply design.
It is here, in this all important power supply region, where voices and instruments take on what is known as proper “bloom” and give us the illusion of being right in the room with us.  The last thing you want is an anemic sounding musical presentation – but with the right power supply, you get the fulness of the music in all its glory.
Built in Boulder: The NWD is in a beautiful industrial design based on the PerfectWave series.  It’s a half width of a PWD and the same length.
This beauty feels just right when you pick it up, its build as solid as it gets and best of all, it’s hand crafted right in Boulder Colorado. By people who care as much about audio as you do.
Bottom line: In the 23 years we have been making DAC’s the NWD is the sweetest, warmest, most open and musical DAC we have yet built in this affordable category.  It will bring new life to your entire music collection – regardless of whether it’s on your computer or your discs.
Regardless of what you have for a transport, from a low cost CD player with an optical output, Apple Airport Express or TV, computer, or even the highest end transport on the market, adding the NWD to your system will bring your music to life.
Digital to Analog converters are the modern gateways for our music collections whether you have a large physical collection of CD’s or you want to venture into the world of ripping, streaming and accessing all your music from the touch of a finger.
It’s a new and exciting world and the PS Audio NuWave DAC fits in perfectly.
« Last Edit: 20 Sep 2013, 01:54 pm by matevana »
matevana
Re: FS: PS Audio NuWave DAC (Excellent)
« Reply #1 on: 26 Sep 2013, 05:06 pm »
SOLD!
