Help with hooking up pre amp with amp and a Nad reciever can I?
0 Members and 1 Guest are viewing this topic. Read 1285 times.
vm84444
Hi there question.
I heard someone on another forum use his pre amp as source hooked
Up to his rotel processor.
Wondering if I can do the same with Nad 761 reciever.
I have 3- channel
Acurus 3x200
And a new inexpensive
Shocking surprising Chinese pre amp below.
CLASS-A - 100% New XIANGSHENG 728A Pre-Amplifier
The back of pre amp and the manual states you can hook up low output connections
To intergrated
High outputs to power amp
Would a reciever work in the mix too?
Hooked to where tape out maybe?
Don't see a
HT bypass/processor loop on the preamp.
Thx a lot.
