SOLD - AUDIO RESEARCH LS15 TUBE PREAMP BLK - $1400
0 Members and 1 Guest are viewing this topic. Read 1483 times.
Chazro
« on: 14 Sep 2013, 10:22 pm »
For sale is an Audio Research LS15 tube preamp w/black faceplate. Unit is in very good condition. Original box, manual, & remote included. Asking $1400 plus shipping (if necessary). Looking to sell locally to avoid shipping. Only USPO money order (Let's talk/text - 561 906 2223).  Located in Wellington (West Palm beach) Florida.
 From ARC website: The LS15 is a line-level preamplifier. It features all-tube gain (12 dB standard) using four 6922 twin triode tubes in a Class A, fully differential zero feedback (balanced) circuit with electronically regulated high and low-voltage supplies. The LS15 includes handheld IR remote control of all essential front-panel functions. An onboard microprocessor controls a 70-step electronic relay attenuator and 5-position input selector. An additional Direct input (balanced) provides a highest-signal-purity path for your favorite music source. A total of two balanced and five single-ended (including tape) dedicated inputs are included.
 Main outputs are balanced and single-ended, with one pair of single-ended tape outputs. Spring-activated toggle switches activate electronic relays to control key functions with minimal signal degradation.
 Control Functions: Volume, Source Select, On/Power, Mute/Operate, Monitor/ Source, Direct/Source. Handheld IR remote control included.
 Inputs: Direct BAL; Input Select BAL, SE 1-4, Tape Monitor.
 Outputs: Record SE, Main SE 1, Main Bal 2, Main Bal 3.
 I'm also selling an Audio Research PH3 tube Phono Preamp (Blk faceplate, original box & Manual) for $750. Will sell both units to same buyer for $2000, a very sweet deal!
« Last Edit: 2 Oct 2013, 05:09 pm by Chazro »
Chazro
Re: FS - AUDIO RESEARCH LS15 TUBE PREAMP BLK - $1400
« Reply #1 on: 25 Sep 2013, 10:40 pm »
Bump
