What tubes to use after upgrade?
0 Members and 1 Guest are viewing this topic. Read 1563 times.
ricmon
« on: 13 Sep 2013, 05:31 pm »
Hello team AVA I  have had my TR-7 upgraded to an Ultra II in Jan 2012.  My question is concerning tubes.  Should I continue to use 12AT7A tubes in the line section or 12AX7A tubes?  The original 12AT7A's we left in after the upgrade.
thanks
Ric
avahifi
    • http://www.avahifi.com
Re: What tubes to use after upgrade?
« Reply #1 on: 14 Sep 2013, 12:18 am »
Continue to use a 12AT7 tube in the line stage.  They are a higher current tube then the 12AX7 tube and are biased on harder.  A 12AX7 is a bad choice for your line stage.  It trades off higher voltage gain (not needed in this application) for lower current output (which is needed).
Frank
ricmon
« Reply #2 on: 14 Sep 2013, 12:37 am »
Hello Frank thanks for the advice.  The pre is just a great piece of gear and was just thinking of getting a back up pair of some Telefunken's and wanted to make sure that I was getting the right value tube.
ricmon
« Reply #3 on: 14 Sep 2013, 12:53 am »
One last thing. Should I keep using the 12AX7's in the phono stage?
avahifi
« Reply #4 on: 14 Sep 2013, 12:48 pm »
Yes
