**** SOLD *** Supra Ply 3.4 S speaker cables
0 Members and 1 Guest are viewing this topic. Read 1760 times.
aragon63
« on: 11 Sep 2013, 11:33 pm »
Unterminated 8ft pair Supra Ply 3.4S ( these are shielded s. cables ). Original owner , they still need additional burn -in time.
The screen stops the radiation of interference fields from the loudspeaker cable and eliminates its influence on the sensitive input circuits of the amplifier. Normally, loudspeaker cables radiate stronger alternating fields than those of ordinary mains cables .The screen is meant to be connected at one end only, to a ground screw or to the chassis of the amplifier, whereas the shield should be left disconnected at the other end (the loudspeakers end).
Very neutral and well balanced cable. The bass range is well extended and harmonically rich with a vibrant "oomph", powerful and controlled till the deeper end. The best quality of the bass of the Ply 3.4 S is its linearity, that is the flat frequency response, no peaks and no weak spots...
The mids are neutral and the sound is never "in the face", always controlled and undistorted: voices and acoustic string instruments flow through this cable effortlessly .
   $ ?? delivered to your door ( continental USA )
« Last Edit: 22 Sep 2013, 12:38 am by aragon63 »
aragon63
Re: Supra Ply 3.4 S speaker cables
« Reply #1 on: 12 Sep 2013, 09:42 pm »
 Sale pending to Thirsty
aragon63
Re: **** SOLD *** Supra Ply 3.4 S speaker cables
« Reply #2 on: 17 Sep 2013, 11:05 pm »
SOLD
